This looks like a boost leak..
GIGANTORE
As a general rule, accumulation of oil around a hose that recirculates charged air is a sign of a boost leak. This appears to be a little dryer than most that I’ve seen. But this kind of accumulation doesn’t happen without a leak.
Very possibly.  If the PCV system is performing well otherwise, you would get less of an accumulation at the leak site.
It might be a wise time to invest in some HOTPIPES.IMHO.  Z
AIR PIPE - FORD (BA5Z-6C646-A)
$257.80
https://parts.levittownfordparts.com/oem-parts/ford-air-pipe-ba5z6c646a/?c=Zz1jb29saW5nLXN5c3RlbSZzPWludGVyY29vbGVyJmk9S0QwOTA2MzUmcj0xMiZhPWZvcmQmbz10YXVydXMmeT0yMDE0JnQ9c2hvJmU9My01bC12Ni1nYXM%3D
https://parts.levittownfordparts.com/auto-parts/2014/ford/taurus/sho-trim/3-5l-v6-gas-engine/cooling-system-cat/intercooler-scat/?part_number=aa5z9u465a
ZSHO said:
It might be a wise time to get some HOTPIPES.IMHO.  Z
$257.80
Thanks for the link. Agreed on the Hot pipes. Especially since the oe part is so damn expensive. Just wish I could buy just that one from them.
glock-coma said:
Also that clamp looks like it’s been removed before.
Good eye.  I didn’t notice until you said something. But you’re right. The color change in the lettering, shows that the clamp has been moved.
Did you happen to check out the rear?
I would also add a 1/4 clamp to the waste-gate hose that connects to the intake charge pipe!  they have a tendency for coming off due to boost psi .
Those Darn VTA Mods ! Lol . Z
bpd1151 said:
ZSHO said:
Did you happen to check out the rear?  Z
Well ahem......
That's a double entendre if I've ever seen one.
LOL
I will let you know when I wake up and get a cup of Joe. Lol .Z  :sleeping:
I did check the rear turbo hose. No signs of leaks. I prefer zip ties to those 1/4 clamps.
Did you ever figure anything else out about this I'm having a Wastegate flutter on my 13 sho and I believe it's because of the same hose
