Throttle Body Motor assembly
Hopefully it is a quick visual inspection and nothing more :D  I would also ask Mike about hotpipes with bungs at the opposite end of normal (at CAC instead of TB), black powder coated if you think it will help pass inspection. Ecopowerparts.com
Same here with the adjustment cap. I think that missing cap is a major contributor to the contamination of the motor assembly by allowing so much boost leak.
I was also spraying about that using the nozzle that came with the alky controls kit,  but I want to drastically cut the amount sprayed, I know you are spraying 100% meth, but 9GPH converts to just over 567ml a minute, pretty substantial. Most people see better results performance wise with less and spraying less will probably also save our Throttle bodies.
To give an example, I planned out my Port injection project with 6 32ml per min nozzles per port, plus two pre-TB, one just before it and two at the outlet of the Intercooler. All with 32cc nozzles it works out to about half the theoretical flow rate at 9*32= 288ml per min on paper. (1GPH=63.09 * 9 = 567.81 ml per min) Depending on who you talk to and want to believe, our setup doesn't need more than 400ML max, (a little under 7GPH).
I assume that you Dyno tuned your ride with your current setup, do you know if your tune is relying on the meth for extra fuel or just using it for safety and charge cooling? When I had my ride dyno'd they were able to achieve 430/430 with 93 octane and using the meth only for charge cooling and a safety net, however, when the meth really kicked in it would really fatten the fuel up and bog the motor some even some audible break up. Mix was about 70/30 Meth/water.
I also just noticed that you are running a HPFP. I would highly recommend that you experiment with your meth setup to find the sweet spot for flow rate vs returns as You dont really need the extra meth "fuel" unless your pushing for higher numbers.
Do you plan on progressing further on the fuel system? Stronger Low Pressure in tank pump? Bigger DI injectors? The Motor can make way more than the trans can take if you do... kinda why I am sitting at my current power level with no plan to go bigger for the moment, just working on dependability/operation of the meth "safety" system.
Originally I ran this much meth as a buffer for not enough fuel with the stock fuel pump.  With the larger HPFP I probably don't need to run this much meth but it runs so well right now I don't want to change anything.  I ran the 1/8th mile recently and the MPH equated to ~600HP to the crank.  With the larger turbos there is much more power available but I am happy... for now.
That was my very intention was to add an additional 7th injector last year but after careful analysis it was not recommended in my case IIRC!
I also noticed Prometh does not offer the direct port setup using the 7th injector!
I would start off with a smaller Nozzle because sometimes less is more,especially when adding an additional injector,as you increase orfice it increases methanol. So adding another jet will add volume shot in...
It will ultimately need a retune and would leave the decision to your Tuner IMO!  Z
YUP, you are correct, pro meth does not offer direct port kits for the SHO, I had to piece mine together with single serving parts from them and Devils Own. Havnt ran it yet, but I did come up with a solution for the additional nozzles... OR you could order a generic kit for a V8 and then order the other pieces to make it fit for what its worth, I just didnt feel like bending the steel straws at the time... if anyone is interested I can start a new thread with more details of my build plan and parts list so far...
YES indeed i agree, less is MORE. That is why i went with the smallest nozzles I could find @ 32cc.
