Timing system changes
Not technically a technical article, but needs to be documented.  Will be updated as research is ongoing :)
2010+ Taurus SHO Primary Timing Chain
Production Date: 02/2011-
Ford Part No.: AT4Z-6268-B
Belt - Timing Primary
Replaced By AT4Z-6268-C
Production Date: 06/2009-02/2011
Ford Part No.: 7T4Z-6268-A
Chain - Timing Primary
Ford Part No.: 7T4Z-6268-CA
Chain - Timing Secondary
Require Quantity 2
Package Quantity 1
Camshaft Position Sensor aka Phaser
Passenger Side
Production Date: 08/2010-
Ford Part No.: BA5Z-6A257-C
Sensor - Camshaft Position Intake , RH
Replaced By BA5Z-6A257-E
Driver Side
Ford Part No.: BA5Z-6A257-D
Sensor - Camshaft Position Intake , LH
Driver Side
Production Date: 06/2009-05/2010
Ford Part No.: 7T4Z-6A257-A
Sprocket - Camshaft
Replaced By 7T4Z-6A257-B
Passenger Side
Ford Part No.: 8T4Z-6A257-A
Replaced By 8T4Z-6A257-B
Why the gap in the phaser part info, no idea.
Differences between the timing systems as a result of the updates are listed in the attached PDF downloaded (along with images) from the following site:
https://www.fordflex.net/forums/viewtopic.php?t=16661
1st generation chain:
index.php
2nd generation chain:
index.php
Pics from the referenced article comparing old Gen 1 to new Gen 2 primary timing chain:
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
Hmmm...
I can tell you this, since we had the entire timing set done on the Lincoln, KR is a rarity. I would have thought my sensor was broken if it wasn't happily adding.
For the 1st couple of months after we got it back, never saw more than .09. Yes, that is correct. Two months in I finally got a +3 on an extended logging/hunting session.
Now i have to look and see if i got the updated parts.
"Timing system" is right that's a lot of parts that need replaced
You would be surprised how hard a time I have convincing people of that, LOL.  Unfortunately, there are a LOT of moving parts to this system, and if just one goes wrong, it casts doubt on the rest of them.
