SHOdded said:Sounds terrible
SHOdded said:Did you post the invoice of the repair work? I would like to see what all they changed out. Strange the noise goes away after warmup. Sure you have put 5W30 in there? Belts and tensioner look OK? Motorcraft oil filter in use?
The sound really troubles me!MiWiAu said:SHOdded said:Did you post the invoice of the repair work? I would like to see what all they changed out. Strange the noise goes away after warmup. Sure you have put 5W30 in there? Belts and tensioner look OK? Motorcraft oil filter in use?
Post 33 has the estimate with all the parts. I’ll have to check the repair order to see if they specify the oil type used. The replaces the oil and coolant after the repair. I haven’t changed the fluids since the repair.
I just left town for work, so I won’t be able to do anything with it until Friday.
SHOdded said:timing tensioner?
MiWiAu said:SHOdded said:timing tensioner?
I believe he was referring to the serpentine belt tensioner. Will confirm shortly when I pick up.
I’m a bit skeptical, but trying hard to give them the benefit of the doubt. Worst case, I bring it back tomorrow...
Macgyver said:So when did you get the ESP ? I was thinking about getting one soonish.
SHOdded said:Would be great if this is true, fingers crossedFirst instance of rattling caused by belt tensioner. Usually it's like cards in bicycle spokes kind of "flitting" sound, mostly on colder days/near freezing & below.
