FoMoCoSHO said:
Actually I've been studying egts and its not quite that simple.
If you don't believe me let off the gas and put your car in decel fuel cutoff than watch your cat temps plummet. That is the leanest mixture you will see yet the lowest cat temps.
I agree, its not that simple.
But I think the cat temp is the wrong metric in this case. The deciding factor for that is exhaust flow. During decel, RPMs are decreasing which means less exhaust gas is hitting the cat. I think that, because this is about engine oil, the graphic is referring to engine temperature.
