Torque Pro profile set up and initial start up
Seems like the easiest  solution would be to pull out the MX tool when you park for the night. I understand it might be a little inconvenient but way easer and faster then having a dead battery all the time.
bigmoneycloser said:
FoMoCoSHO said:
Are you closing Torque when you get out of the car? If you leave it running in the background on the tablet, that may be the issue.
Testing that right now
You should also be able to set up your notifications on the tab to alert you in case you forget. My phone tells me constantly when I am changing dashboards or whatever when I'm in the house.
On my set up, torque goes to sleep (not off) as soon as power is cut. The Nexus follows in going to sleep in seconds. The MX takes care of itself. On power on everything reverses.
The MX is not the cause of the dead battery. It is all in the set up of the tablet and the App.
Ok
So this is what I found. When I kill power the nexus goes instantly into sleep mode. Which means torque is running in the back ground and the mx stays on and continues to have BT searching for connection..
But, if I quit torque and then kill power, the mx BT shuts down after about 6 minutes.
So that is pretty perfect....
I'm not sure if the BT is what killed my battery the other day or the nexus drawing power, but it should all be resolved now.
Thanks..
You don't have to manually quit Torque. You simply find the Torque set up menu and set Torque to go to sleep on power off. The Nexus is also separately set up to go to sleep a few seconds after power off. You then let the MX go to sleep on it's own. Simple, clean, automatic. Works every time. Almost every time that is. One time the Tablet locked up on me and stayed on when I shut off power and I had to reboot the tablet to get everything working again. I guess all things computer may need an occasional reboot.
One more thing.....if you are powering the Nexus from a power source that is dead when the ignition is cut, there is no way the tablet could drain your battery. That is key. You need to use switched power source!
There is a known issue with torque and the MX sleeping.  If you checked the box in torque to put the mx to sleep it actually can keep the mx awake.  I was told to uncheck this box then hold down the button on the mx until the led's start scanning.  This puts the mx back to its stock setup and it should sleep properly.  After you're away from the vehicle for a couple hours look at the mx (if you can) before opening the door or unlocking the door.  If the green light is on (or blinking?) its not sleeping.  Anything that causes a battery voltage dip (parking light flash, dome light, door locks) will wake the mx up.  The mx WILL deeply discharge your battery all on its own if its not turning off.  It's current draw by itself taking no readings is pretty high, ask me how I know  :'(
You should root your nexus so you can quit torque, turn off the radios, and sleep the device when the ignition is turned off.  Then when you turn the ignition on it will wake up the nexus, clear the keyguard, turn on the radios, launch torque, and do what ever else you want.
Ok
Thanks..
Bluetooth consumes a fair amount of power. Consider the difference in battery life with your phone when BT is enabled. I love the feature in Torque that turns BT on and off your device on program start and end.
Yup
I think I got it figured out.
As long as I quit torque, the obd shuts down and stops searching for BT and the nexus sleeps at ignition kill.
Good to go
