I've been lurking since I first saw the 13 sho. This is my first post. I purchased a '17 sho in march of 2020.
I had considered using carb cleaner or brake clean to out what I assume is a "sponge" in the cap that has gotten clogged allowing pressure to build up, but I thought I'd post it here to see if anyone else has had this occur and what the fix was.Thanks, Joe.
The past 3 oil changes (5,000 mi.) I've noticed the plastic valve body cover was moist as well as the bottom of the trans. It looks like there is trans fluid coming out of the vent in the fill cap.
I've search for this issue, but the only thing that seems to come up on the 6f55 is the seal leak on the output shaft and where the two trans halves are bolted together. I had considered using carb cleaner or brake clean to out what I assume is a "sponge" in the cap that has gotten clogged allowing pressure to build up, but I thought I'd post it here to see if anyone else has had this occur and what the fix was.Thanks, Joe.
