Backstory - I have a 2015 SHO with GH tune. I smoked the trans at 60K. It kept cutting RPMs trying to power brake before hitting the 2K limit. The tuner said it could have been sensing converter slip and killing power. One power brake attempt the revs shot up to 4K and the car started rolling while I was standing on the brakes. Needless to say smoke, stink then no go! Rebuilder said converter was completely fried which burnt fluid and took out the clutches and a steel.
Now I am paranoid! I have not done a power brake since I got the trans rebuilt. This weekend I picked up a ScanGauge II and am monitoring trans fluid temp. I noticed it can also measure Converter Speed Ratio (slip?) Just curious what parameters I should be keeping an eye on and what numbers are bad?
Temp is usually around 190F (I drive pretty aggressive) and will jump to 200F after a 1/4-mile pull.
Also any recommendations on a better gauge? The ScanGauge is real-time but no peak reporting or warning light capabilities. I'd at least like to have a warning light when a parameter reaches a certain set limit.
