cnatra said:Anyone have some good pics (or how to thread) of a SHO transmission drain and fill ?
Thanks
Thanks
ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
I believe it was $99.00 for this procedure IIRC! Z
StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
I thought flushes were not recommended? By the time you get done buying 18 quarts of fluid, doing three drain and fills, its cheaper to have a shop do the flush...
No need to get Technical! Lol. Zsm105k said:StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
Even doing the flush (which isn't recommended) only removes 10 out of the 18 quarts. Yeah doing the exchange over a period of time is more expensive, and yields more fluid exchange while not being as abrasive on the internal parts of the trans. I don't want a vac hose being rooted around my trans personally.
ZSHO said:No need to get Technical! Lol. Zsm105k said:StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
I used 10 quarts Total.
So is the drain and fill 5 or 6 quarts?sm105k said:ZSHO said:No need to get Technical! Lol. Zsm105k said:StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
I am "special" and really gun shy about my trans. I will be doing the trans fluid exchange (5 out, 5 in) every 3k miles along with my oil change. Completely overkill yes, but overkill is good.
BlueSHO said:So is the drain and fill 5 or 6 quarts?sm105k said:ZSHO said:No need to get Technical! Lol. Zsm105k said:StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
Sent from my SM-G950U using Tapatalk
10-4sm105k said:BlueSHO said:So is the drain and fill 5 or 6 quarts?sm105k said:ZSHO said:No need to get Technical! Lol. Zsm105k said:StealBlueSHO said:ZSHO said:I had the Ford dealer perform a Trans flush which they hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid.
Technically whatever your take out. Mine is usually around 5 quarts.
Makes sense IFZSHO said:FWIW- Here is the actual response from the Ford dealer. We cannot do an actual Trans Flush, what we do is hook the trans flush machine up to it and do a flush through the dip stick. It will still use 10 qts of fluid to do the service. Dunno!
I apologize for the confusion. Z
Gray Brick said:I drain and fill on every oil change and get 5-6 quarts exchanged.
I really should be doing this more often on the PTU.
