Hey guys,
2010 SHO non-pp. 145,000 miles.
Recently, the car has begun to shudder at light throttle right after the torque converter lockup in 3rd gear. Sometimes somewhat violently. If you power through the shudder it will smooth out. Doesn’t happen at wide open throttle.
Fluid level is ok after checking it hot.
It also displayed the signs of a bad Transmission Range Sensor recently, by slipping out of drive and also not displaying it was in park after a cold start with the associated wrench light on the dash.
Thoughts anyone on the TRS?
