Im already out of warranty, so nothing really to lose at this point.TopherSho said:I'd be very careful tossing a rod, if the dealership/ford network/warranty-company has you marked down as 'modified' they will not honor a engine rebuild. I ran into that with my Bad injector taking my block out. I had to pay out of pocket.
Understand the frustration though...
I would like to believe this is true, but i really dont know. I had too many things happen at once for me to point it directly at the flash. Im mostly leaning towards the condensation causing the problem. I cant confirm 100% what the boost was directly after the misfire because i was stock tuned and wasnt paying any attention. As soon as i got the tune back on is when i noticed the problem. And when switching back to stock i noticed it was still present because i was paying attention to it. Granted this was after the dealer flash, but i still cant confirm thats what caused it.SM105K said:The Dealership did it. It most likely corrupted the ECU with the new flash.
Thank you! Im going to try the pedal out of my dads truck this weekend and see if thats it.SHOdded said:Both codes are pointing to the wawa pedal, not the throttle body, so that's what I would check first. Highly unusual for it to be that, but if there has been water intrusion of any kind, then it is quite possible.
P2122 - Throttle/Pedal Position Sensor/Switch D Circuit Low
Description: This DTC sets when the accelerator pedal position 1 (APP1) is out of self-test range low.
Possible Causes: APP1 circuit open
APP1 circuit short to ground
Damaged APP sensor
Diagnostic Aids: An APP1 or APP_D sensor PID reading may indicate a concern.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test DK .
P2127 - Throttle/Pedal Position Sensor/Switch E Circuit Low
Description: This DTC sets when the accelerator pedal position 2 (APP2) is out of self-test range low.
Possible Causes: APP2 circuit open
APP2 circuit short to ground
Damaged APP sensor
Diagnostic Aids: An APP2 or APP_E sensor PID reading may indicate a concern.
Thanks man me too. Been doing alittle bit of reading. If its not the throttle pedal, it could be a bad wiring harness or a bad pcm. Really hope its not either of those but i guess i will find out.SM105K said:I really hope this works for you.
I have pulled the 2 main harnesses off the pcm and everything looks fine there. Nothings corrodedTopherSho said:With the whacky OAR reading, I am leaning to a harness issue or at the lower end of possibility a ECU causing it to adjust itself. Have you pulled the harness off the ECU? Z/SHOdded have seen corroded plugs before..
Only 2 on mine unless im missing somethingZSHO said:There should be 3 harnesses connectors! For reference here is good link for ya. I think you Need to provide as-built-data. Z
https://circuitboardmedics.com/ford/
Both MAP sensors identical or what are you asking? So far no more codes after switching out the pedal and it does feel somewhat better, BUT i did put my pedal in my dads truck, and his still runs perfect. So is it just in my head that mine feels better maybe. I guess i need a few more days to see what it does.SHOdded said:Oh man! Really hope the PCM is not bricked! It should detect issues with the MAP sensors but ... are both identical on your F150?
