Took SHO for spin to store. Car would not shift gears. Would over rev, and still not shift. I put car into manual and tried to shift manually, and nothing. Pulled car over. Restarted engine and drove off. Same thing.
This time, car would not even go into gear initially. Finally did, but the shifts were inconsistent and car would still over rev and not shift. Seems I've had something with the transmision ever since installing LMS tune. But I dont drive car enough to say there is definte problem. After 6 months, I only put 4000 miles on car in which roughly 3000 are with tune. I did not have problem before hand.
Is this something others are seeing or have seen? Starting to wonder if the LMS tune is flawed on my car, or is there a problem with car itself? I removed tune and got DTC P00C2. Which says bad turbo bypass valve. Could this be causing my issues?
