I am in the process of getting a replacement engine as mine is toast after water pump went out. More than Likely I'll end up with a used engine and while it is out on an engine stand I am going to do some PM like water pump, timing chains, other gaskets. As for the turbos, I am trying to not spend too much money, but I also think it would make sense to at least replace the seals in the turbos while I have easy access to them.
At this point I'm looking for recommendations, whether it makes sense to just replace seals in my stock turbos or rebuild them with better parts, or just outright replace with the ATPs.
Thank you!
Thank you!
