Unleashed / datalogging ??
68_GT
OK so my blown engine SHO is up and running with a bran new long block, upgraded turbos, and Unleashed tune. Runs very strong even for his base beginning tune although I haven't got on it too much sine I have maybe 200 miles on the new engine and initial oil still.
So I want to start data logging now to se what the car is doing just not sure where to begin with the X4.
thanks in advance guys. Lots more to come with these EBP upgrade turbo wheels. It feels stronger than ever but sure is quiet !
Torrie has a config file that he will send you for logging/ monitoring what he needs. Once you are tuned in, you can create your own config for boost, knock, etc.
the X4 says datalog on it and has a record, or begin datalog or something so I guess it's not that easy as hitting that and driving around....
I'm kinda afraid of the X4 messing up my ECU or something, so not sure if I can just leave it on all the time and turn the car off and on and use it like normal ??? anyone mount the X4 ?
cool thanks !
However, when you hit record it's a one time deal. So do a wot run from 0-100 ish then stop recording. If you do it again you will record over the data that you just logged. You can however hook it to your laptop and do several and keep them in your laptop. Again don't ask me how.
Yes you can mount the X4 with the "gauge" display running and it turns on and off automatically with the car and will keep opening with the gauges displayed.  I ran mine that way for a month or two before I "upgraded" to the livewire TS+
Setup that way it can also one touch datalog.  Just be aware the X4 by itself is a slow datalogger so does not give great resolution.  Most tuners want you to have a laptop plugged into it to get full resolution log files when they are tuning your car.
My X4 recorded more than one pass if the passes were quick.  I think it has a cap on how long the log can be?  I know I had multiple pulls on my log, though they were all done in the same drive, no key cycle between them.  That may be what resets the log file?
Don't know. Started ticking at 70k miles. At 130k miles it turned into more of a rattle. At 133k all hell broke loose.
Always ran Mobile 1 FS oil changed religiously myself. Random BS far as I can tell... wish I hadn't spent $3,300 on timing chain, chain guides and tensioner at 60k miles from chain rattle....
Dang man. Totally sucks. Sorry for your luck.
