Updating Tuner
KonaTheWhale
Would there be any benefit to updating my Livernois tuner? I got thinking the other day and wasn't sure if they keep pushing out updates to revise the tunes or once you have it that is all. By updating I mean to connect it to your computer and run the tuner update application. I haven't done any other modifications and have had it since the spring
I update the update software periodically and check for hardware updates. As the other gents mentioned, the tunes themselves are only updated based on request and if available.
Sent via my Speak and Spell
My MyCal touch is so old (bought it in '11) that LME has to email me tune update files and yet they still support me with updates and no complaints. Great customer service.
2010 Stl Bl Met, Loaded, non PP, LMS 4+X, K&N drop in, 170 T-stat, 3 bar MAP, SP534
Lol a dinosaur tuner lol.....and no need for a pat on the back for doing the right thing...glad they still supported the customer lol
Ditto for me. I have the MyCal touch too which I got in 2012.  LME (Jaimie) continues to make it all work for me with updated tunes.
One good thing about the old MyCal touch is that it holds a bunch of tunes. I can't remember the limit, but some over the top number like 50.  I should count but I think I've got at least 10 on there.
Remove & replace the SD card (with same memory capacity,  or larger) & you can hold even more.
Oh yea, I forgot about the remove able memory card. It's actually been a pretty good all round tuner!
Thank you for the kind words!
Yes the others are correct on the tuner updates.  The only thing it may find periodically is an updated firmware which typically is to add support for newer VINs such as adding the 2015-16 vehicles to the list of supported VINs.  We would have to actually setup updated tunes specifically for your serial number which is a case by case basis.
