ElvenSho said:I am seriously thinking of ordering that kit from torrie but need to find someone to install it for me. (Plan for next summer)
Definatly meth. Besides. You will need the meth for upgrading the turbos for the extra fueling it provides. And it's not too bad to install to be honest. PS... I'm in Bettendorf Iowa. ;-)
Sabtaj1 said:I am in waterloo! Do you have meth installed?ElvenSho said:I am seriously thinking of ordering that kit from torrie but need to find someone to install it for me. (Plan for next summer)
tuned for meth and meth fails at wot= extreme lean condition = kaboomCroR1 said:How reliable is meth? What happens if it malfunctions while at wot? What's the risk, is the question?
SHOdded said:If yiu are running meth, you do need to keep an eye on the meth tank levels. A pretty simple check to add to your routine.
Sabtaj1 said:SHOdded said:If yiu are running meth, you do need to keep an eye on the meth tank levels. A pretty simple check to add to your routine.
Or if your like me and used your washer res, you get the low washer fluid light come on inside the vehicle. Works like a charm...
PokerMunkee said:How did Bob with the red Flex in FL blow up his engine? I know it was his fault, but he was running meth at the time.
