So I'm going thru my logs now that I finally figured out how to use torque map view to read logs
What does bad timing look like? I think it's if you see negative spark but at what point?
The way I started going thru this is I found a section with high engine speed (rpm) then looked at boost pressure ( throttle Inlet pressure) then looked at timing then air fuel ratio
