Vta
Brandon2525
Hey guys i have my blow off valves vta how come when i am in park it will not blow off i have seen other peoples sho and when they are in neutral there cars do it?
You could try in drive and holding the brake.....torque is limited in park and neutral ....you could have your tuner crank that up
When you roll off the throttle you should hear the pffffft,did you try power-braking it as AJ Suggested,any pics of front & rear install? Z
Ajp's and Z are correct. When you don't ask for torque there is no boost and so nothing really to blowoff.  Power braking may do it, but if you get the rpms too high in that case then the boost may dump with the same result... There are other benefits of VTA besides sound... The PCV empties into the intake... Closer to the front turbo... With VTA you take a step toward minimizing the recompression of that stuff with it's volatilized oil and fuel. Might help slow turbo coking.
Maybe take off the engine appearance cover, see if it makes any difference?  A K&N intake (metal-bodied) also adds some of that turbocharged-audio bling.
I was curious if you ever fixed your issue with no vacuum on boost gauge a while back and if somehow these two issues could be related,just trying to isolate the root cause for ya.  Z  :)
No i still still not fixed issue on vaccum for boost gauge have not had time to look at it yet thanks to everybody for the help.
