Wastegate dumping boost
askoncemore
What would be the cause of the wastegate to go to zero?
The attached picture shows the boost is great and then it starts to drop off at around 80MPH
Any suggestions on where to start?
Two things I noticed:  a) the FRP is constantly oscillating (not by a whole lot (500 psi maybe) under WOT and b) lambse is identical between banks 1 & 2 at part throttle at 23mph starting at row 6444.
I think the ECu did if anything.  Something possibly the issue with a sensor.  Waiting for AJ to chime in.
GB, Look at throttle angle actual and dsd...
It looks like the ECU shut the throttle on you unless you inadvertently let off.
Any chance you forgot to turn off TC?
If not, we can't tell where the request came from because you're not logging torque source.
That is one of the strangest logs I have seen.....There is an element of time involved....Like timers for the torque limits maybe...Ask torrie how the LAMBSE is coming down in a linear fashion as the pull goes on.....It's coming down independent of RPM , gear and load, I've never seen that and would have no idea how to do it.....Just guessing here but I'm thinking he is doing that in an attempt to correct the fueling for meth addition...Since I've  not seen good logs with meth in terms of fueling
The car is over fueling because it doesn't know where the meth is coming from so stft's plummet and you reach the max amount allowed to be pulled
So you are commanding a leaner mix early in the pull  and that may slightly help with trims which are about .85ish then as the pull goes on you command a richer mix so the car dumps more fuel plus your meth then the trims go to .75ish.
Something gets unhappy eventually and boost is dumped
It's really weird
You can get away with commanding .90 Lambda because  in reality you will be richer than that because of the meth you are dumping and it will stay rich because you are dumping more meth than the ECU can compensate for to maintain lambda by removing fuel via STFT
Gray Brick said:
TC was definitely on.
What other PID's should I add to my logfile to help figure this out?
You're at 40 so you are maxed out on pids.
If I were you I'd make another log file and get rid of the dupes you have for US units and just change the others to what you want.
Torrie can read both so set them to your preference.
Add torque source.
The more pids the lower the refresh rate.
