What is wrong with the suspension in the car I test drove?
johnbowler
So I test drove a 2014 SHO last week and liked the way it drove and handled.  My wife test drove a different SHO and liked the way it drove and handled.  We went to look at another one today (the one that we want to buy) and drove it but it rode very hard and jittery.  Rode like my WRX, not the other 2 SHO's we test drove.
Theories?
First one had 3,000 miles, next one had 100 and the one with the "issue" had 25.  All non-pp.  I can't find one with PP on Long Island.  Don't exist unless I order and I don't have time for that.
Theories?
I have a 2013... It had 1400 miles on it and I have always loved the ride.
The first thing I would check is the information displays (screen to the left of the speedometer) to see what suspension mode the car is in... options are Sport, Normal, and Comfort  (stiffest going to softest).  Most likely this is what the difference was.   If the dealer doesn't know the instructions are about page 121 in the manual.  The suspension control is under "settings"
SHOdded hinted at the another one... a little run-in still needed to "flex" the springs.
Did you drive them on the same surfaces (roads) or different ones?... that of course could be one effector.
Tire pressure differences could also be in play...
If the rough one had aftermarket larger wheels with shorter sidewalls and therefore less air at a given pressure that could be a big change
If the tires were different makes, that could contribute due to sidewall stiffness differences.
Check out the simple things first.  If you really want the one that rode rough tell the dealer it has to be fixed.  It is possible something is not right, and at 25 miles, would likely not have been noticed yet.
I would not accept the run-in explanation, if that's all you can come up with, without an agreement from the dealer that it should be fine by (miles) or they will repair.
Or just look for another one.. they should be able to get what you want from another dealer.
But get one... you will love it!!
Great diagnosis Dr. BiGMaC.  I agree with the prognosis.  John, you definitely need a SHO to cure what ails you!
Really, you change the suspension settings on these cars??  Mine is parked in my garage for the winter but I want to go out and check this out if this is true.  I've played with the setting quite a bit but did not see anything regarding changing the suspension settings.
Click the image to enlarge:
Thanks for the great responses.  I wasn't aware that the car bad different suspension settings.  Nothing I read said anything about different settings!  The roads I drove on were similar.  Actually, the roads I drove on in the car yesterday were probably the smoothest.  All wheels were 19 inchers and factory wheels.  I don't know about the tires.  Didn't check on that one.  HAD to be the settings (I hope).
SRT82ECOBOOST said:
So how do you actually change the suspension settings?
On the '13 at least...
•Select settings in the in the left screen (or on the main touch screen if you want... I just try never to touch it personally)
•Toggle to "Driver Select Suspension" and selecting it will bring up choices
  -> If your transmission is in "D" you will see three options: Sport / Normal / Comfort
  -> If your transmission is in "S"  you will see two options: Sport / Normal
•Select the one you want, Hit OK when toggling back out of the menu
It is an option.  The manual says if it doesn't appear the car doesn't have it. This info is on the page before the one I posted.
Are you guys with 2013 SHOs saying your cars were available with the driver adjustable suspension?  I thought  that was a Lincoln-only feature.  I realize the owners manuals for the Taurus and MKS show the same information about that but I was not aware it was even an option on the Taurus.  There is certainly nothing about it in any sales brochures with the Taurus.  In Lincoln sales materials, it is a major highlight.
I don't recall this adjustable suspension being an option on the SHO. I've had my 2013 (non PP) since October and have never seen this in the menu. Is this on the Lincolns maybe?
Perhaps this is the answer to the mystery!
It is definitely on the 2013 and newer MKS.  I do not believe it is available on the SHO regardless of what the manual says or what the menu options are under "settings."  If it is available on the SHO, I will gladly eat crow - medium well, if you please.
My salesperson isn't in today but I will call her tomorrow and ask her some of these questions.  My theory?  I know some other manufacturers deliver their cars with "pucks" in the suspension to prevent the cars bouncing around during transit.  I have read that some people that complain of their suspension still have these in their car.  This car was on the showroom floor so was probably never prepped.  That's my theory.
Welcome.
I also just went from a WRX (2012) to a 2014 SHO.
Your going to want to get a tune if you want the same smiles per mile as the WRX.
Compared to the WRX a stock SHO is a nice car but no where near as entertaining (fun to drive) as the WRX. With a tune its a totally different car.
Speaking from experience, the SHO should ride a LOT better than the WRX, and I have 20 inch wheels on my SHO.
I can't even compare my WRX to the SHO, let alone any other car.  The entire suspension was modified as well as the entire driveline and engine.  It had nothing in common with a stock 2002 WRX except the body panels.  I know I am not going to get anywhere near the same ride/speed/acceleration/handling from anything other than a true sports car.
Time will tell... especially ride (comfort), acceleration, and speed (the top speed limiter is turned off by most tunes).  Your sitting on a 4.3 0-60 with basic mods in a nonPP and challenging Porsches, BMWs, vettes, and a raft of other cars that cost 2-3 times as much. You may be surprised.... Plus it's fun owning a sleeper!
BTW... Excellent thought about the transport suspension dampers!
I realize I can tune the car, what I meant to say was that no car in my price range would give me what I had STOCK.  Sorry for the confusion.  I know this car has a lot of room to "grow" which is one of the reasons I am probably buying it.
My 2013 SHO does not have adjustable suspension.
It also doesn't have that sweet looking intelligent AWD gauge which really irritates me.
Too bad 47 grand doesn't buy a model specific owners manual.
