I'm thinking part of my wheel hop issue is with rear shocks going. As I launch the front end lifts to much because of weak rear shocks + tires spin and lift, then grab and hop up again. Feels like a quick couple jabs to the front suspension.TSS said:I had what I described as a 1-2 stutter under WOT . Can you describe wheel hop to me? Perhaps its the same thing I was experiencing.
I just got a B&G transmission fluid change, rear differential fluid change, coolant change, and PTU fluid change. I can't swear by it, but the runs I have taken so far, only two of them, there was no shudder/sutter. It's too cold here to really test right now, but I'm going to continue testing to see if somehow, with those preventive maintenance items, it went away.
While we're at it, what's that shutter feel like to you?TSS said:I had what I described as a 1-2 stutter under WOT . Can you describe wheel hop to me? Perhaps its the same thing I was experiencing.
They are....ZSHO said:I think those coilovers are calling for you Rich![]()
When I hit 2nd at wot it shudders which I'm describing as wheel hop. It comes from the front and it feels like the front is hopping up and down as it spins.TSS said:I had what I described as a 1-2 stutter under WOT . Can you describe wheel hop to me? Perhaps its the same thing I was experiencing.
