Wheel hop under hard acceleration
SHOdded said:
Being a UHP summer tire, and with this statement "g-Control sidewall inserts featuring up to a 40% higher sidewall stiffening structure to improve lateral stability and cornering precision", I would say the sidewall is as stiff as or stiffer than the Super Sport.  Since TX has widely variable weather depending on where you are/where you primarily drive, your choice of tires likely would change accordingly.
My choice is between the BF comps or Hancook Ventus 12s
You mean the V12's, BiGMac?  I see Tirerack is showing 2 versions, the Evo2 and the K110/evo.  Both are directional tires, with the Evo2 geared towards fuel economy as well.
http://www.tirerack.com/tires/BigPic.jsp?sidewall=Blackwall&tireMake=Hankook&tireModel=Ventus+V12+evo2&partnum=435YR1K120XL
http://www.tirerack.com/tires/BigPic.jsp?sidewall=Blackwall&tireMake=Hankook&tireModel=Ventus+V12+evo+K110&partnum=145YR8K110XL&fromSurvey=true
Price for 20" stock size 245/45/20:
EVO2 - 169
http://www.tirerack.com/tires/tires.jsp?tireMake=Hankook&tireModel=Ventus+V12+evo2&sidewall=Blackwall&partnum=445YR0K120XL&tab=Sizes
EVO - N/A at this size, but the line is on closeout on tirerack
1010 tires does have them but more expensive ...
http://www.1010tires.com/Tires/Hankook/Ventus+V12+Evo+(K110)/1009171/size/245-45ZR20-XL
UPDATED w links/corrections
SHOdded said:
You mean the V12's, BiGMac?  I see Tirerack is showing 2 versions, the Evo2 ($150/tire) and the K110/evo ($84 on closeout).  Both are directional tires, with the Evo2 geared towards fuel economy as well.
Yea Manu... Ventus V12 evo2... hope to 1+ tire size to see if a little more footprint decreases 0-60 noticeably.
