Where can i get a set of pp calipers
IGottaShoYou
Upgrading to pp calipers where can i get some fast tasca has to special order them like everything else
I think mrhighcaliber was able to procure from his local Advance Auto/AutoZone, so maybe look at the stores first?
You may want to check to see if they are even different. My non PP sho had everything but the pads and struts as far as brakes and suspension go.
If it's the later cars (13+), the only difference is the pistons (vented) and dust boots (Silicone).  The rest are the same...well, pad material I think is different.
If you have an early car (10-12), I have a set of PP fronts that are rebuilt with metal pistons (stock are phenolic/plastic).
