white smoke and smell gas
beaven69
hi i'm new here
I made a diagnosis to stock 2010 Ford Taurus SHO
I wonder if the p00c6 code and failure p0304 is due only to the injectors or may be another cause?
and ask before buying and read most of this great forum and obtained a lot of information but this time if I am in doubt
someone who can help me with advice
Thank you
thanks for advice and help
i just remove the plug #2 is wet gas
i change the position of the plug with the coil
and continues to set P0302 and p00c6
I do not think I can avoid change injector
beaven69 said:
i just remove the plug #2 is wet gas - changed position...
Id try changing the plug first. I always start with the easiest cheapest solution.
So you mean that you changed the plug and coil with a different Cyl and the original cyl is still flooding?
yes, changed coil and plug to a diferent cyl  and still the code p304 and p00c6
and spark plug #4 smell fuel , the white smoke still
after a long wait to change the injectors was the only solution
code p00c6 and p304 are gone
now the codes p2196 and p2198 any sugestion
