Windshield Washer Pump
Anyone have issue with their windshield washer pump? Thought I was out of fluid but it only took 1/2 gal, hit the button - wipers go but no spray and no sound of pump. Any insight into how hard it is to pull the tank/pump? 2012 SHO w/PPm w 42k mi.
Thanks guys!!!!
Mark
Thanks guys!!!!
Mark
Yeah mines not working right now. It was working but I  found a small drip from the pump so I took it to the dealer. When they "fixed it" I got home to find out it doesn't  work now. Hah
So I'll take it back and see what's going on. Not that this really helps you. :/
If you pull the inner wheel well cover you can get easy access to the pump and resivour. I might just fix it myself.
Sent using smoke signals.
wasinger3000 said:
Thanks guys!!!!
Mark
Inner wheel cover is what I was looking for. May dig into it tonight and see if its just a loose connection or what. Mine is not leaking, just not squirting .....
