11BLKFX4EB
Is it possible that an O2 sensor got damaged during the swap? I agree the data logs would be a huge help. If sounds like a spike in AFR and the car trying to compensate wich would cause the sputtering.
ZSHO said:Brenton keep us updated cause i know how fustrating it can be,had a few issues myself which later the dealer was able to fix under warranty,have the platinum extended warranty for a total of seven years. Z
14SHOCAR said:I stopped by my tuner this morning and he is going to update his diablo tuner to see if the sputter is misfires.
I am going to reset the PCM per the previous thread in a couple of minutes here... I have a long drive down to Vernan Hills, IL from Milwaukee and back today -- which will give it a lot of drive time to adjust ****. It's super frustrating but its worth a shot.
My tuner is also going to be "test" loading a DiabloSport Tune on my vehicle. We are going to see how that tune works so I can go back to LMS to see WTF is going on.
I am getting the feeling that the LMS tune does not reset the shift points or the adaptive fuel curves when you install the tune. I think you HAVE to do a PCM reset every time to get less aggressive fuel curves. At idle, my car is spewing white exhaust on a 60 degree day -- it smells very rich (it doesn't smell like burning oil at idle).
I also am experiencing a rough idle too... Straight up frustrating.
14SHOCAR said:How does adding E to your gas test* the winter blend? Don't you think that we pay for a tune to not cause misfires ... Not to cause problems... Livernois should come up with a fix for this??
ajpturbo said:Also, I highly doubt you are running rich at idle...that's where logging is the only answer rathe than speculating...the only way u would be running rich would be if u were in open loop and only a complete moron would force open loop at idle for this application....actually these cars run closed loop in a way even at wot but I won't really get into that now .....
11BLKFX4EB said:Wouldn't a bad O2 also cause the car to run rich?
ZSHO said:I apologize for intefering,but this is reference to the OP.was curious to know if you used new gaskets x4,or if you re-use the old ones it will leak causing o2 sensors to read incorrectly causing fluctuations on your AFR. Z
I did the PCM reset yesterday because I'm pretty desperate for answers here..... and I haven't had a rough idle since. This problem is now ONLY at WOT.ShoBoat said:Just to clarify mine only had issues at WOT. Not at part throttle and at idle.
AJPTurbo -- I drove around with one of the Diablo tuners connected + a tech. He said at idle my A/F was "around 14" Not sure exactly that is good but that is what he stated.ajpturbo said:Sure..I guess that could....damn he could use a log lol
You should be able to run it. All it will do is throw a code, and that shouldn't come on for about 50 miles. Should be plenty of time to log and see if it shudders. If it still shudders, my money is on a bad o2.14SHOCAR said:I can't because I have catback... I'm assuming the stock tune doesn't have the rear O2 delete
SRT82ECOBOOST said:The lack of a great sound from these cars is what eventually drove me back to a V8 platform. Either it is no sound or a ricer sound without anything in between.
