WTS: 2 RX Catch Cans (OCC) with Clean Side Seperator (CSS) - **SOLD**
Status
Not open for further replies.
JimiJak
**EDIT - BOTH CATCH CANS HAVE BEEN SOLD!!!
Hey All!
Doing some winter clean up and figured I would offer up some Team RX Oil Catch Can kits I have in the garage. I actually have two full kits I’m not using and can part with. The details are listed below.
Standard size catch can with clean side separator and install / mounting kit
I had installed this one on my '14 Explorer Sport for about two years. You can see the write up on the kit / install HERE. All of the fittings and parts that were originally included are still with the kit and in great shape, plus some additional connectors and parts I picked up or made. The hoses are simple rubber evap / fuel line and I’ve included a spool of what I have left which gives you the freedom to run this can in a different application than how I did it. This was their premium kit when it was purchased, though they've made a couple of changes between then and now. This kit was originally designed for the SHO / Flex, but will also work for the Explorer, and I’m sure most other ecoboost vehicles. There are some signs of wear and tear from install / use, but everything functions and is in good working order. Also I had added some epoxy around the joints in the CSS to avoid any oil seepage.
$145 including shipping to the US!
**SOLD**
Monster catch can with clean side separator and install / mounting kit
I used this one for R&D to determine whether or not there was enough room to install the Monster can on an Explorer Sport. The monster can will fit as long as it’s located in the same place I installed my standard can (in front of the driver's front tire, behind the bumper cover). It will also fit the Longitudinal F-150, but is likely too big for many other vehicles. This kit was used for fitment and design purposes, so it has been installed, but I uninstalled it shortly thereafter. Other than a couple bumps from install, this kit is still brand new!
$200 including shipping to the US!
**SOLD**
CLICK HERE for the RX website.
Pics are below, the standard kit has the black can and CSS, the monster kit is in red.
FYI these kits take a bit of creativity to install, that's just the nature of the beast. Both kits include all of the hardware that was included directly from RX, and then some, but plan on a trip or two to the hardware store for miscellaneous connectors, hoses, etc.
PM me any questions and I'll do what I can for you.
THANKS!
oJ8nvqjqlZ2vWSP0uZFpuDrMJTDNjm_2SJHFrguXY8WQSBTkr1S8KXGbhso58GN9lee_aVAXpifWtX093xlUjCNAPZwObqK_6Xet8wB2zEDImDgYglvlme7GjKoPNyu31oruhoTIzYQe4CL-JUdm9yrDnH8nOkK9ECsaB9qic2yMZM-FS-NZN6MpavOkK6zLz2F11T2C758zBCH6N54Et1LE8QE13Sb6DtIzYCNmWpmQ48o1_EaDZrDjGDyL2_lxq1yjzPsoZlJC6u6N3NM1ZiKyXhn1CUaKNidlK8qQkbOcDcvfWOqkdfxQB8K6EXgrqEv_HI3xIzEL7XpKXMojthQF4IlaLsRAFJadfPBgRJUdK65T2dygoroRL9w5f-qyRVSQq7gyWZTDI_1n71ZHIKsaSpg7reT35FBvTKzjb0MsdSpJlBaOBvnhfMT3UAdrykCROpNMdlj8_POx9UshjOTiynVZOInuVGOT9iRyTzJCoS1AQOfs4Cwpi5YNkyDZkyb5mcy13kg-NNJYZnP_3cffn629YS6i7qwYNKJ0LKT_vtnLlYHqGhWUwOjZ8yG-OXkDyUmdooN4Yisg8ZhmdNzF626OhKxQm5sUhvoOcFl2K7Qjk67y=w725-h638-no
--iTMUE4p-FnnEM8bzs7qmhAtF_LzOBhaciJW0iUO32E-UVjjhS8xnTyD5vkhDO7txELXXzcwD-RVDLgOJM8TDOlGNv6u-8kMAyLzpQEUhIIwUQyGHSVemBNtjbXJVcrJ6F7EGx3zG_nCCSnoVmm7rA-C_D4c2qLCBUlM3dw5Sw3NhQXPRW7qqcKzdiZZS_MJXQwwi17VvznPnY1WHtEkGPCoBscYwkoY1lZ3BNZb0iavWJAHJ8oNg4SebrfmmjjnUn1htydx47sHq-g2t8eLpidB8_oVABGktW8LkVAy-ROr1YT0yCxdg7vj6WkR7DB2g5yBEOlIfdMlAV_VzUkm8VBPjMaPh6TvkQ9JRoSvNp_0qPOlBxp0DeQ72a5OnemFagwzpqHESDPXvJ808dpDX3-zGYYrCd3AV3RTtvvk_UGN6HBysuigARknwUAlN2SKs3ke3lni-6RlNncp1PayDVwdp6zb9Mh6rEESvrn3pw7X8GZz-c09_ZRHjkFtgiCdnPDU2aJLjHixrj4xJO5jFFbtooYu9rZcUlJ2M5vIiRbNSXcQ6M9RXKhVgZ0-LlsCUNUUiHyAJbAsZJ6G_sSak2C8mbwP-8flr6zHz7_JNm22efJTusO=w692-h638-no
What, no pics???  And yes, folks, JJ is still alive LOL!  As per the rules, please post pics of your offerings identified with your forum name and location as soon as possible.  GLWS!
I am! Life's been a crazy ride since my "disappearance". I've been popping in to stay somewhat in the loop, but mostly just lurking in the shadows.
Looks like the pics didn't come through for some reason, I'll try again.
stand by...
SHOdded said:
You need to come out of the shadows, man, get your post count up.  Barely past the 500 mark!!!
You're not wrong! Especially now that I have two EcoBeautys!
So the only modification/tapping of the factory system required is the Clean side fitting into the stock airbox area behind the filter?
There have been quite a few advancements and a lot of growth on my discoveries from 2014. I would recommend reading up in the PCV / Catch Can threads about the best way to install. I know there have been some efforts to avoid drilling / tapping all together.
Welcome back JimiJak and purchased my Rx OCC from BMC(Bigmoneycloser)a while back and sure is a quality piece for sure...GLWS Brother .Z
Status
