Blackhawk said:What is the deal with the confusion with extreme-DI and LMS. I know I've seen a previous post from LMS staying they are developing their own and it is not the same as the RTR pumps. What pump was LMS referring to when they said they are developing "that" pump.
I didn't know about an upgraded di pump solution until this thread. So thank you. I didn't even know that lms already had one available for the f-150.StealBlueSho said:Blackhawk said:What is the deal with the confusion with extreme-DI and LMS. I know I've seen a previous post from LMS staying they are developing their own and it is not the same as the RTR pumps. What pump was LMS referring to when they said they are developing "that" pump.
I was unaware there was a previous discussion about it. LMS tends to rebrand stuff, had I known there was already a thread about that aspect I wouldn't have brought it up. However, the original intent of this thread was that extreme DI had listed the SHO pump as available...
http://www.hotrod.com/articles/direct-injection-mystery-solved-injectors-pumps-ecoboost-tensema16/ . Zmrhighcaliber said:I didn't know about an upgraded di pump solution until this thread. So thank you. I didn't even know that lms already had one available for the f-150.StealBlueSho said:Blackhawk said:What is the deal with the confusion with extreme-DI and LMS. I know I've seen a previous post from LMS staying they are developing their own and it is not the same as the RTR pumps. What pump was LMS referring to when they said they are developing "that" pump.
Sent from my Nexus 6 using Tapatalk
SHOnUup said:I can vouch that Livernois is not rebranding these...they are created in house...eye witness here
Glad to see you posting once again stranger. ZSHOnUup said:I can vouch that Livernois is not rebranding these...they are created in house...eye witness here
Its available but limited to in house install only IIRC. ZShoBoat said:Any update on the Xtreme DI pumps?
ZSHO said:Its available but limited to in house install only IIRC. ZShoBoat said:Any update on the Xtreme DI pumps?
StealBlueSho said:It's two torx screws, a quick fuel disconnect, and a 8mm nut on the fuel line to the rails....
The only thing I can think of is if the the new spring is really strong making it difficult to install..
Technically you are supposed to align the the engine to TDC so the cam lobe the HPFP rides on is at its lowest point... this makes it easier to put the the HPFP in as you don't need to compress the spring much to get it in....
ShoBoat said:StealBlueSho said:It's two torx screws, a quick fuel disconnect, and a 8mm nut on the fuel line to the rails....
Sounds easy enough, I think I'll put a call into them and see what they say.
You are correct from my understanding only E85 capability needs in house install.StealBlueSho said:Based on the F150 pump from LMS its a direct swap... when I called they said it was a direct swap...
Not sure about anything special for E85....
