02 SENSORS!
Here are the part numbers for the 02 sensors and a TOTAL OF FOUR are required on the 13+SHO.
I found the best price @ www.rockauto.com with Promo-code attached below.
THE FRONT PRIMARY 02 SENSORS HAVE THE SAME PART NUMBER & TWO ARE NEEDED.
MOTORCRAFT DY1185- 8F9Z9F472H
$59.79
THE DOWNSTREAM FRONT 02 SENSOR ONLY REQUIRES ONE SENSOR
MOTORCRAFT DY1155- BH6Z9G444A
$52.99
Here is a PIC of of the DOWNSTREAM FRONT SENSOR which is located underneath the oil filter for reference.  Z
THE REAR DOWNSTREAM 02 SENSOR REQUIRES ONE SENSOR.
PIC BELOW.
MOTORCRAFT DY1167- BA5Z9G444A
$36.79
I found the best price on www.rockauto.com with Promo-code below.
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,oxygen+(o2)+sensor,5132
Promo-code 7101DF2E857469
Expires: June 26, 2018
So it’s (2) widebands MOTORCRAFT DY1185- 8F9Z9F472H, (1) front downstream MOTORCRAFT DY1155- BH6Z9G444A, and (2) rear downstream MOTORCRAFT DY1167- BA5Z9G444A for a total of (5) sensors?
I’m still waiting for my (2) BA5Z9G444A to come in.  Figured they would have been here by now...
The 2012 SHO Setup is slightly different IIRC. Z
2 - FRONT PRIMARY 02 SENSORS.
MOTORCRAFT -DY1185- 8F9Z-9F472-H
4A
$52.99.
Rear Downstream o2 Sensor.
MOTORCRAFT - DY1167-BA5Z-9G444-A
TOTAL OF FOUR 02 SENSORS.
I wonder if there are several variants of these sensors that fit the 2010 SHO, I happen to be looking to replace one of the upper ones and have found:
Rockauto lists Motorcraft DY1120 - 5F9Z 9G444 AB https://www.rockauto.com/en/catalog/ford,2010,taurus,3.5l+v6+turbocharged,1445050,exhaust+&+emission,oxygen+(o2)+sensor,5132
Amazon confirms DY1120 fits the 2010 SHO https://www.amazon.ca/Motorcraft-DY1120-Oxygen-Sensor/dp/B002WHCAKC
and Tascaparts calls for 8F9Z-9F472-B https://www.tascaparts.com/oem-parts/ford-oxygen-sensor-8f9z9f472b/?c=Zz1lbWlzc2lvbi1zeXN0ZW0mcz1lbWlzc2lvbi1jb21wb25lbnRzJmk9TVAwODE1MDUmcj03JmE9Zm9yZCZvPXRhdXJ1cyZ5PTIwMTAmdD1zaG8mZT0zLTVsLXY2LWdhcw%3D%3D
AFAIK Amazon has a history of providing inaccurate part numbers and would make certain to cross-reference the part number prior to ordering.
I would also add Rockauto the the list .
I believe the correct part numbers are listed below.  Z
MOTORCRAFT (8F9Z-9F472-B) - $54.68
https://parts.levittownfordparts.com/oem-parts/ford-oxygen-sensor-8f9z9f472b/?c=Zz1lbWlzc2lvbi1zeXN0ZW0mcz1lbWlzc2lvbi1jb21wb25lbnRzJmk9TVAwODE1MDUmcj03JmE9Zm9yZCZvPXRhdXJ1cyZ5PTIwMTAmdD1zaG8mZT0zLTVsLXY2LWdhcw%3D%3D
MOTORCRAFT DY1120 - 8F9Z9F472B  - $46.79
https://www.rockauto.com/en/moreinfo.php?pk=2314656&cc=1445050&jsn=450
