Hello everyone, I wish my first post was a good one but as the title says, I lost my engine the other day. Seems the water pump/timing chain is a common part to fail in high mileage bulls.
My question today is will a 2013+ engine with transmission and turbos fit in my 2010? I read that the cam sensors, crank sensor, crank sensor tone wheel, and coolant inlet tube would need to be swapped over from my 2010 engine but that's all the help I've found and that didn't cover anything that would possibly need to be swapped out on the transmission.
I've been following everyone in here with their mods so I'm chomping at the bit to get up and running! I'd love to upgrade the turbos but this kind of stomped that budget. So I'm thinking a compressor wheel and wastegate upgrade while the engine is out, along with the supporting mods needed to get the most out of them.
Thanks in advance!
Thanks in advance!
