Also a flashing cel usually means the engine is cutting fuel to save the catalytic converters from damage. So you could have a bad fuel injector.
glock-coma said:Also a flashing cel usually means the engine is cutting fuel to save the catalytic converters from damage. So you could have a bad fuel injector.
sholxgt said:I cleaned out my IC when I first bought the car. At 27,000 miles there was already some build up. Not a bunch, but enough to convince me that it needs to be checked every few oil changes and cleaned as needed.
FaSSt9602 said:sholxgt said:I cleaned out my IC when I first bought the car. At 27,000 miles there was already some build up. Not a bunch, but enough to convince me that it needs to be checked every few oil changes and cleaned as needed.
How did you clean it? I was thinking of taking it to a radiator shop and having them dunk it...
Mine has just shy of 100k. At about 60k I got a new shortblock due to a cracked piston, which caused excess blow-by and oil everywhere. I question whether the dealer was smart enough to clean things out when the had my car for months on end waiting on the new block...
SHOdded said:Hmm possibly a split pipe, or a leak from the front turbo oil cooler line? Rooting for the split pipe scenario.
