thewrubelator
Got the truck Dyno'd today at Shelby. Was on a Dynojet. Couldnt be happier with th results!!
2012 F150 Ecoboost Dyno pull
thewrubelator said:Mods are in my signiture. Yes stock turbos, the 22psi is a little high, Shawn from SoCal is going to adjust the tune to get max boost around 17-18psi. A lot safer, until I get upgraded turbos.
SHOdded said:And you are running the stock turbo! Look at the boost![]()
darreli said:thewrubelator said:Mods are in my signiture. Yes stock turbos, the 22psi is a little high, Shawn from SoCal is going to adjust the tune to get max boost around 17-18psi. A lot safer, until I get upgraded turbos.
So were the boost levels the same between LMS and SoCal?
thewrubelator said:darreli said:thewrubelator said:Mods are in my signiture. Yes stock turbos, the 22psi is a little high, Shawn from SoCal is going to adjust the tune to get max boost around 17-18psi. A lot safer, until I get upgraded turbos.
No, LMS was around 17 max boost.
darreli said:thewrubelator said:darreli said:thewrubelator said:Mods are in my signiture. Yes stock turbos, the 22psi is a little high, Shawn from SoCal is going to adjust the tune to get max boost around 17-18psi. A lot safer, until I get upgraded turbos.
So it makes sense that you made more power..I'd like to see the comparison at the same boost level
