First off, 2013+ owners that have installed the LMS/Alky kit - which fuse are you using that is ignition on only? I know 2010-2012 use 46. I found 70 which operates some of the same things that 46 did in the other years and I am getting power still when turned off and in accessory. When I shut my car off the meth pump kicks on and the red light is on for priming then it finally turns off after about 10 sec. Weird.
Other than that it's working fine. I do have another question about pump priming...
I do not have a tune but I wanted to try the kit out and make sure it was working properly. I took a 50 mile drive on the interstate and set the controller on 2. When I was driving with cruise on even the slightest incline in the road that would put a load on the engine the red priming light would come on. Should it be coming on this early? Even driving without cruise on the interstate I would have to baby it up hills to keep the priming light from coming on.
I verified the settings inside the controller and they matched others.
I had about 2 quarts of 50/50 meth in the tank and ended up between driving a total of 60 miles with it on and spraying to test in the garage it used it all.
... And yes I will be getting tuned for the meth when I get my turbos on
Thanks in advance for the info!
