2013+ ignition fuse and pump turn on q's
Mikesb said:
I tried to run the 3bar before the tune and dang, the car sure didn't like that.... I'm assuming the tune corrects the vehicle for the use of the 3bar
That is accurate.
It's not a matter of "correcting" the vehicle, rather, correcting what the ECM is reading.
If you haven't adjusted for the signals the 3bar MapV is sending/receiving to the ECM (and other sensors in / along it's arterial path) via means of tuning,  and you just install the 3bar, without tuning for it accordingly, you will experience the results you've previously reported.
Thanks for the words of support. I also called Julio and ran down my install procedure. He said "that it, you are good to go" got a blizzard out in front of my house at the moment, probably not going to tinker on the car tonight. If the snow shuts me down from work tomorrow I'll getherdone. Almost afraid to ask if I need a tune for my down pipes??
Glad you got it straight... don't wish you bad weather, but I do wish you time to complete things soon and then weather to enjoy the mod!
As far as the downpipes... the car will run fine without changing your tune, but there are tweaks they can make  that will change your tune to get the most from your DPs... Faster yet!!
You will need a tune for dps as well. Depending in who's pipes you use and if they are catted or not. Car will run fine without tuning for, but you could throw codes.
Supposedly those don't throw codes. But you will still need a revised tune to get full benefits of the dps.
""". GREEN LIGHT. """
I'll see what I can do for testing, but I don't know just had a snow storm
Haven't tuned or install 3bar yet. I'll do that here in a minute
3bar and tune worked fine. Before the tune the red light came on real easy and I got a green once. After the tune I think I got a couple of red flickers. To much ice and snow I guess. Suppose to melt Monday
Looks like you still have air in the line. It may work its self out, but sometimes you have remember line from spray nozzle and hold test button to purge it all out. But for purging you need to turn the gain all the way. You can also rev your engine up to about 3k and hit test until light goes green.
Mikesb said:
ONLYA6. - SUP WITH YOU RIDE?
Still sitting at Livernois, status unknown. Day 15. All that needed done before tuning was swap out the 3 bar, plug back in the relay signal wire for meth and toss on a new front O2 sensor. It threw a code on the way there.
Wa Wa What...?  Over two weeks?
crash712us said:
When is the last time you spoke to LMS about your car?
Thursday 2/27 I got a quote to replace the O2 sensor after it had been there for 11 working days.
I dropped it off on 2/15 due to the dyno being booked week of 2/24.
Ok what to make sure you where apprised to everything when BDP inquired about it, when he was in town. I was there when they detailed the status of your car.
Yea it also needs the relay signal wire plugged back in for the meth and 3bar installed. Looking back I wish I would have just taken 2 minutes and done it when I dropped the car off. Now It's getting added on the bill. *sigh*
Where they up front with you on how long all this would take?  I hope you have another driver, or that rental bill will be pretty high by now.  :0
