2013 PP front brake pad part number
I just spoke with a buddy of mine which is a senior tech at Ford,and the correct front performance package pads are DG1Z-2001-D if you have painted calipers,for non painted calipers the part# iS DG1Z-2001-F.hope this helps someone.
Very true Z... If you go to the parts pages I posted earlier there are separate part numbers if the caliper is black from the one that's "silver"... the black is the "painted" one... both numbers are there to compare and they are identified as to whether they are for the black or the other.
ZSHO said:
BiGMaC said:
I apologize for that Tom,was trying to update my post from Dec,Z.
No problems... not a dis at all.  Thanks for pointing it out.  I only found out about the difference when I sourced the page... and it was on my second look... Good info!  You probably saved someone a week and a restock fee.
The part#DG1Z-2001-D is only a painted option to match your painted black calipers,part# DG1Z-2001-F are silver oem PP pads just like BigMac said earlier,just to clarify the painted black brake pads are for those that have painted there calipers black to [match] thanks.
