2016 SHO - differences in PCV system
I have a 15, that was build date 12/1/15 so I will check mine and see which set up it has.
What track do you guys run at? Best I got was 14.1 stock, but could have probably gotten 13.99 if I had traction control all the way off and pulled the extra stuff out of my trunk.
13.5 stock is pretty stout.
Curious what's the last 6 digits of your vin?
PM'd ya.
metroplex said:
Hi Jim! Glad to see you made it to the forums. You definitely have a sharp ride! Just out of curiosity, what was your best trap speed for the day?
Best trap was 103.73 mph
Here is my '15. Seems like my car may be a hybrid of the pre '16 system and the '16 system. I have the composite covers, and a direct connection on the rear valve cover. However, there is no sensor/wiring in the front location.
Pics attached.
SHOdded said:
Build date, derfdog?
EDIT"  N/M 12/1/15, not so early in the cycle ...
That is correct, a few days later and it would have been built with the first run of 16s.
Still seems odd that is has some of the changes but not all of them.
It is.  Because this new tube incorporates a sensor, one would think it was not a random parts bin snatch, but there is a batch of cars whose as-built is like this.  Maybe AJP can look into the as-built to see if there is an on/off switch for this sensor, which would make the decision on the floor that much easier.
Ill point him towards this thread and see if he can shed any light!
Yep my 16 was built a few days after your 15. It is odd you have some things on your engine that aren't on other 15's but they didn't put everything the 16's have. You don't have sync 3 like the 16's do you? Now that would be awesome
Unfortunately not, SYNC2 V3.8
