wasinger3000 said:It's a 13. I'd say the build up comes from the cylinder itself somehow. Because my intake tracts are all bone dry. No traces of oil at all. So I have no idea how it's building up except for coming back threw the intake port. If it was from the intake side you would see little trails of oil in the manifold. But there isn't a trace at all.
I do run lucas UCL. Not sure if it helps or hurts the carbon buildup. But I do get around 2-3 mpg better on the highway.
Sent using smoke signals.
Spartn27 said:wasinger3000 said:It's a 13. I'd say the build up comes from the cylinder itself somehow. Because my intake tracts are all bone dry. No traces of oil at all. So I have no idea how it's building up except for coming back threw the intake port. If it was from the intake side you would see little trails of oil in the manifold. But there isn't a trace at all.
Carbon build up is not directly correlated to oil being in the intercooler, the latter is just a symptom that usually is there when there is excessive buildup though is not always certain. With our direct injected fuel system the gasoline is sprayed directly onto of the piston whereas a regular fuel injection system sprays the gasoline through the intake valve openings which cleans the valves basically every time the car is running.
Only real way to solve this issue is to do intake valve/fuel system cleaning intervals, to use quality and higher octane fuel, and/or methanol injection which will clean the valves every time it is activated.
Impressive gain!wasinger3000 said:I do run lucas UCL. Not sure if it helps or hurts the carbon buildup. But I do get around 2-3 mpg better on the highway.
SHOdded said:Impressive gain!wasinger3000 said:I do run lucas UCL. Not sure if it helps or hurts the carbon buildup. But I do get around 2-3 mpg better on the highway.
ShoBoat said:I did the seafoam a while back with no apparent I'll effects. It actually felt like it ran better after I was done. Just use it slowly like I did over about 15-20 min. I used about 1/2 can. I plan on doing another soon. I will do a before and after on the valves.
panther427 said:You values looked fairly carbon free. But they seemed wet . So oil is getting to them. I wonder if changes where made to system for the 13 refresh?? ?
wasinger3000 said:ShoBoat said:I did the seafoam a while back with no apparent I'll effects. It actually felt like it ran better after I was done. Just use it slowly like I did over about 15-20 min. I used about 1/2 can. I plan on doing another soon. I will do a before and after on the valves.
Have you tried using the deep creep stuff by seafoam? It's supposed to really break carbon down. What I did was take the map sensor out and sprayed into each venture of the manifold in hopes to cover each valve.
ShoBoat said:wasinger3000 said:ShoBoat said:I did the seafoam a while back with no apparent I'll effects. It actually felt like it ran better after I was done. Just use it slowly like I did over about 15-20 min. I used about 1/2 can. I plan on doing another soon. I will do a before and after on the valves.
This is what I used,
It comes with a tube that is slid under the intake tube just before the tb. And this allows you to slowly add the seafoam to the intake track. Almost the same point of entry for the meth kits I have seen.
