Black Dream
Couple of quick questions. Just installed a 3 bar with Unleashed tune on the MKS and I kept the stock thermostat in to see how she ran on a very short run. Like a beast of course, noticeable power difference with peak boost at 19#, previous high with my 93 Performance tune was 16.2. I've read that it's ok to run with the stock stat but saw temperatures vary today 5-6 degrees from the pre-3 bar tune I've been running. Normal cruising temp for me has been 193-195 and on this short trip they spiked to 198-201. When the thermostat opened then all was back to upper 180's to mid-low 190's but the temps seemed faster to ramp up than before. I ordered a Reische 170* today and wanted to see if the recommendation from the masses was to drive it as is, carefully, or replace the stock MAP and re-flash that tune.
Also is our recommended coolant, VC 10-A compatible with the VC 10-A-2? I'm thinking the 2 is just an updated version but could definitely be wrong. Seems Rockauto has the best pricing on the 2 version.
And finally a mini-rant. I bought a 3 bar from one member here and when it arrived I sent it back because the number on the part didn't match the number on the box. Box says AA5Z-9F479B, sensor says AA5A-9F479-AB which is the exact same part number as the factory MAS that's installed in front of the throttle body. When I opened the second sensor I got from a different member today voila, same scenario. I attached a picture for clarity. Because the car's running great after installing the new MAP and 3 bar tune I have to assume the sensor is correct but I'm soooo confused lol.
