CaptainInsane-O
So... aside from custom fabbed, there are no 3" exhaust systems available for the SHO?
SHOdded said:You mean turboback/catback? No prefabbed that I know of.
3" downpipes you can get from Unleashed Tuning, I think.
CaptainInsane-O said:Kinda disappointing / surprising that nothing bigger than 2.5" is readily available. Turbo cars like to BREATHE...
Loud is no problem for me, I'm coming from an '05 SRT4 with 3" mandrel pipe from the turbo back & a Dynomax race bullet muffler where the cat used to be. Ride before that was an '01 Lightning with Bassani headers & exhaust.
CaptainInsane-O said:Exactly how small? Are the turbos' specs available?
I'm coming from an SRT4 & the Skittle's turbo is pretty pretty itty bitty but it definitely benefitted from moving from a 2.5" Mopar exhaust to a 3" B&B knockoff.
AJP turbo said:CaptainInsane-O said:Exactly how small? Are the turbos' specs available?
The sho’s Turbos are smaller I think...that’s why they can make 20 psi if programmed correctly...not that we have the fuel for that anyway....also you dopar only had single exhaust..so do the math on dual 2.5” pipes ...it’s a lot more than a single 3” pipe
Only smaller turbos I have seen were on motorcycle turbos lol
SilvererSHO said:AJP turbo said:CaptainInsane-O said:Exactly how small? Are the turbos' specs available?
Not a whole lot though. A single 3.5" exhaust will flow better than a dual 2.5" exhaust. Single exhausts flow better than dual exhausts because they keep the exhaust gases hotter than a dual exhaust. Dual exhausts expose more surface area to the atmosphere and run cooler. Cooler air is thicker and flows less than hot air. Same reason black cars are faster than silver and white cars. ;D
AJP turbo said:SilvererSHO said:AJP turbo said:CaptainInsane-O said:Exactly how small? Are the turbos' specs available?
3" pipe would have about 28% reduction in area so I don't know if I would say "not a whole lot though"...I don't know that the temp of the pipe after the turbos matter much, I think you are reaching there
