3bar map and tip sensor
SHOurpp
where the best place to order the tip and 3bar map sensor for a 2016 sho Taurus?
im getting ready to tune and noticed the f150 is differed from the sho and i need both i think.
thanks in advance
The only thing that you need to replace is the MAP sensor that is directly on top of the intake manifold.  Super easy.
There are two MAP sensors and the second one is already a 3 bar.  I just went to the dealership and ordered another 3 bar sensor.  Was less expensive than I could find online.
so the tip sensor in the throttle body is already 3 bar??
thats what i was asking ajpturbo.
it looks different than an f150 but i guess scanning the values would also determine?
ZSHO said:
SHOurpp said:
ZSHO said:
this is $40 dollars less than dealer
just to be clear the 3 bar map is #cx2231- correct?
Correct the 3-bar is part number CX-2231.  Z
i had to ask because rock auto lists it as located at the inter cooler
You will need to use the same 3-bar map sensor [CX-2231]Listed under intercooler to use on the intake manifold in order to convert from 2-bar to 3-bar when tuned.  Z                      MOTORCRAFT CX2228 .Located on Intake Manifold
$40.99
Add Part
MOTORCRAFT CX2231 {#AA5Z9F479B}
Located at Intercooler
$45.79
http://www.rockauto.com/en/catalog/ford,2016,taurus,3.5l+v6+turbocharged,3357572,fuel/air,manifold+pressure+(map)+sensor,11207?a=Referer+www.google.com+URL+%2F
It is a bit different configuration on the F150 which it is stock on, but Z is correct. Also if you search, rock auto usually has a 6% or 10% off code/free shipping code you can use as well. Should be able to get the sensor for ~$40 to your door.
the 3 bar map for 2010-2016 sho is
$40.99
$45.79  shipped!!
thanks to ZSHO for the info and saving me $40+ dollars by showing me where to get one brand new(rock auto)and the correct part number!
Its always my pleasure to help out in any way i can and due keep us updated on the tune aspect.  Z  :)
