Hey guys,
My 2010 SHO starts but runs pretty rough.
Codes:
P0193: Fuel Rail Pressure Sensor Circuit A High
P0236: Turbo Boost Sensor A Circuit Range
P0642: 5V Sensor Reference Circuit Low
The Turbo Boost, Fuel Rail Pressure, and MAP sensors all share this same 5V reference - which is only reading .3V.
I remove the intake and did a visual inspection of the wiring and can't find any chaffing/short etc
I unplugged the 3 sensors on this circuit and still was only getting .3V at the ECM so i replaced even replaced the computer.....still have the same issue (doh!)
I'm getting 5 volts at pins 1 and 3 of both the MAP and TCBP connectors and only .3v on the reference circuit
Any ideas or hand holding before I throw in the towel? Anybody have access to the pinout tests?
Thanks!!
Codes:
Thanks!!
