ZSHO said:Looks like a promising product indeed,BTW interesting topic over on the Charger forums years back. Z
FoMoCoSHO said:Hi Brian,
After 2 tunes knock is still good.....but I am seeing about a 1.25 degree retard for about the last 1k rpm of third (range .25-1.25). Everywhere else was flat or adding timing.
Do you think I should try the 1 oz to 4 gal ratio like the tt v8 Audis we discussed?
That kind of knock retard is where I net my best times at the dragway....almost done with a tank of fuel from a not so trusted source (Marathon), spiked a random KR of +1 only once on the entire tank too...corn is my friend!FoMoCoSHO said:Hi Brian,
SHOnUup said:That kind of knock retard is where I net my best times at the dragway....almost done with a tank of fuel from a not so trusted source (Marathon), spiked a random KR of +1 only once on the entire tank too...corn is my friend!FoMoCoSHO said:Hi Brian,
Only about 6 weeks from winter blend too
SHOdded said:Good reminder on the winter blend, Rich. Should FIC be added in the rotation to the ACES IV in FoMoCo's ride, Brian?
FoMoCoSHO said:And please don't forget to use the special nozzle adapter that came with your car or your expensive ACES will be on the ground!!!!
BigPelo said:FoMoCoSHO said:And please don't forget to use the special nozzle adapter that came with your car or your expensive ACES will be on the ground!!!!
I dropped my first 2 fillup... Used a 1/2in rubber hose for the third but it was a pain to make it pass the flapper.
Where do I get the adapter?
nickstewartroc said:Do you guys not have one in the trunk with the spare tire?
