Aeroforce Gauges for your Ecoboost vehicle
Sweet! Will be purchasing one tonight.
Just to clarify, if you get just 1 gage you can still have 1 line display constant and the second line can be programmed to cycle?
According to the video that is a YES !
[size=10pt]I've had my Guage Pod  for awhile now and still haven't  decided on what gauges  I'll do . Since My DP's and Torries Tuner are on the way I need to get SERIOUS ..
I like these Gauges but with a tablet  running Torque and Bluetooth Dongle all ways plugged  in  , can you use a OBD II spliter and the gauges still work ?
many out there , but this one is on Amazon :
http://www.amazon.com/OBDII-Splitter-J1962M-2-J1962F-145802/dp/B000TMCX72
If using 2 or 3 of these Guages  do they daisy chain with only one connection to the OBD II port ?
[/size]
ONLYA6 said:
Does it come with the mounting bezel to mount as shown in the video?
It does not come with the pod.
Order received and sent over to Aeroforce!
:) My understanding is 3-5 business days for shipment as they're built to order.
[/size]
I tried to do it and it didn't work for me, you may have better luck but I am not for sure it will work to run the TSX and Aeroforce gauge simultaneously.
My suspicions are confirmed according to the diesel guys also confirmed with Aeroforce:
The problem you're going to run into is that you cannot have two OBD "scan" devices on the CAN bus at the same time. At least not both running at the same time. The reason (and this may or may not make sense) is that scan tools/devices use a specific node ID to request data from the PCM. If you have two (or more) devices on the bus and both are requesting data, the PCM will handle each data request in the order it was received. The problem occurs when the data is sent back to the scan device. Since both devices are listening for a response, both may receive the data but only one will be the right device. This may cause one (or more) devices to display incorrect data and may even cause one (or more) devices to freeze up.
The only situation where this may not be an issues is if you are using one device to monitor transmission only data and another device to monitor engine only data, and ONLY in the case where the vehicle has a separate ECM and TCM... like the 6.0L, 6.4L, 6.7L, etc. Since the ECM and TCM use a different CAN Node ID (0x7E0 for ECM and 0x7E1 for TCM), there is not going to be any conflict as to which device gets the intended data.
There are some other issues relating to bus termination that may also be a problem from running multiple devices on the same bus, but that's another story.
All of this boils down to the fact that it's not really advisable to run to more than one OBD device at a time. If you do, expect unexpected results.
OK  .... So if the SCT iTSX Bluetooth dongle is unplugged and used only for tuning , I assume the same would hold true with trying to run Torque / with a OBDII dongle and the Aeroforce gauges at the same time ?
Just unplug the gauge from the OBD2 port and plug in the TSX. You're not going to be driving around and tuning anyhow, car will be key on but not running.
Let me try to rephrase  this  :  Tuner is UNPLUGED  ..... will the same issues arise with a dongle running Torque and Aeroforce Gauges at the same time ?
IF I buy these Gauges it seems that they must daisy chain ... can you run 3 at once and I would think they would just hook up to the OBD II port via one connection ?
Yes you can't run two different OBD2 readers simultaneously, the dual aeroforce gauge uses it's on special device that shares data between the two display units.
So don't run a bluetooth dongle with Aeroforce, you can run one or the other from what I'm reading.
That being said it's like $17.00 for the cord, buy one and see if you can get it to work. :)
So really what we would need is something that provides a HAL like Windows does, bypassing confusion for the PCM's OBD from multiple requestors.  It would introduce cost, complexity, and slight delays in data display though.
What do you mean by Slight ?  Yeh , money could be an issue to me  but it might be worth it .
SwampRat said:
What do you mean by Slight ?  Yeh , money could be an issue to to me it might be worth it .
It's going to have to be made from scratch and nobody has done one so it's not going to be cheap or even affordable for the first one unless you're an electronics GOD that understands CAN bus data communications and ID. :)
You can have both lines constant, both lines cycling, or just bottom line cycling.
Todd
[/quote]
[/quote]
You can run 1,2, or 3 Aeroforce gauges at the same time, they are programmed to run together.  One connection to the OBD2 port, with the cable splitting to both gauges of a dual set.
Todd
