avidmotion
wow after reading all that I think I am all researched up on the subject now!
ZSHO said:The ATC in turn is controlled by the PCM. The amount of torque is infinitely variable, not just engaged-ON and disengaged-OFF.jims2015 said:ZSHO said:Has the AWD OFF in Dash returned! If not wouldn't worry to much IMO!
The Powertrain Control Module sends a signal to partially or fully engage or disengage the Rear Wheel Drive part of the AWD. Based on input from the (four wheel sensors) feeding the ABS module, the steering-angle sensor module, and the instrument cluster module, the PCM sends a signal to the AWD really module and the 4x4 lock solenoid in the Active Torque Coupling. Z
What do you mean by partially engage? Does the clutch in the unit actually partially slip under certain conditions? I thought it was either on or off.
It can deliver zero percent to the rear, like it does in the Default FWD condition. Or it can deliver anywhere from 1 percent to 100 percent of the engine torque to the rear wheels IIRC! Z
ZSHO said:Good INFO on the AWD & MORE! Z
The Rear Differential Unit on the police version uses a fluid-filled clutch pack, while the retail version uses dry clutches. The fluid-filled RDU can withstand more severe duty.
Both the PI Sedan and PI Utility operate as FWD vehicles until wheel slip is detected. Only then does power transfer to the rear wheels. Of the most importance, the transaxle with water-cooled (police-only) AWD Power Transfer Unit was located. And then the rear axle mounted Active Torque Coupling Unit attached to the Rear Differential Unit was pointed out. On these AWD vehicles, power is continually fed to both the front half-shafts and the rear driveshaft. The driveshaft is constantly engaged and rotating even if power is not fed to the rear wheels.
The Front Wheel Drive system and the Power Transfer Unit send torque back to the rear clutch pack all the time. Any time the vehicle is moving, the driveshaft to the rear is turning. The Active Torque Coupling mounted on the Rear Differential Unit only passes on torque when needed. But it is literally right there when it is needed.
The ATC/RDU used on the Police Interceptors uses fluid-filled “wet” clutch packs. The retail Taurus and Explorer use dry clutches. The PI wet clutches can withstand higher temps and withstand higher temps longer than the retail unit. The ATC and RDU are not field serviceable. In case of a problem with either system, the whole unit is replaced.
http://www.hendonpub.com/resources/article_archive/results/details?id=5091
