StealBlueSho said:How are you achieving 2700 psi at the fuel rail?FoMoCoSHO said:The only difference I can find is the LPFP.SHOdded said:I wonder if there are enough differences between the '10-'12 and '13+ fuel systems to cause an issue with ethanol in earlier MYs. That would be a dig to find that info!
I have an excellent tuner.
I've been saying for a while that the fuel system is plenty capable but was being limited by Ford and it seems he figured it out
I know the conventional wisdom says FRP drops are normal.
But if you are commanding 2150 and only getting 1200, I would disagree. The last thing I want when boost and spark is spiking is rail pressure dropping.
There are all kinds of issues when your rail pressure drops, atomization suffers which causes wall wetting, which can cause knock.
Turning on torque management will help but not completely fix the issue.
