I was looking for a set of Rotors to compliment the newly acquired HAWK-5.0 Carbon Ferro-Carbon compound brake pads and found a couple of Good Quality Performance Rotors without having to break the bank..
The WAGNER Rotors are made from cast iron,while the BENDIX are made from ACP, Alloyed-Carbon Performance castings!
I believe Both Rotors have the Vane design feature which provides greater cooling capabilities @ a similar price point. Z
Both Rotors Replace Original (OE) Part # DG1Z1125C
A precision cut finish of the outer diameter prevents improper balance issues that can result in a loss of vehicle control
A smooth finish aids in the proper seating of the friction resulting in less time needed for pad “break-in”
A unique vane design provides greater cooling capabilities resulting in increased stopping power and decreased noise, vibration and harshness
E-Shield coating is applied to all non-braking surfaces which prevents corrosion and is visually attractive
Tighter tolerance specifications reduce thickness variation and lateral run-out to ensure a balanced rotor that reduces pedal pulsation and extends pad life
Wagner utilizes a combination of premium grade iron, a stringent casting process and a controlled manufacturing environment which results in superior braking performance.
https://www.fme-cat.com/overlays/part-detail.aspx?brandId=WB&pNum=BD180535E&partType=Disc%20Brake%20Rotor
https://www.rockauto.com/en/moreinfo.php?pk=6439056&cc=1503823&jsn=541
The Bendix are madeBuilt to withstand severe duty performance demands with superior thermal stability and strength
SurfaceLok™ Coating is heat resistant and extends rotor life by limiting corrosion build-up
OEM driven machining specifications allow smooth pad-to-rotor contact, improving pedal response for safe driving in all conditions
Made from alloyed carbon performance rotor castings.
https://www.carid.com/bendix/fleet-metlok-premium-severe-duty-front-brake-rotor-mpn-sdr6201.html#specifications
https://www.rockauto.com/en/moreinfo.php?pk=7480876&cc=1503823&jsn=579
Bolt Circle Diameter (IN) 4.500
Construction Full Cast
Disc Finish Directional
Height (in) 1.850
Material Cast Iron
Nominal Thickness (in) 1.264
Outside Diameter (in) 13.858
Rust Resistant Coating Yes
Slotted No
Height (in) 1.850
Material Cast Iron
Slotted No
WAGNER BD180535E
BENDIX SDR6201
