BoostfoSHO
I got both nozzles the 7 and 10 I'm gonna log with both. I'm sure I'll stick with the 10 cause the outside temps have been over 100° everyday.lamrith said:Why not go to the 10 they recommend rather than going for the minimum? If you are going to do it, do it right and make sure you have the meth spraying that they recommend rather than scraping by and wondering. Minimum is not the goal imho when it comes to kits like this. I love to save a buck, but not at the sake of undersizing things. It's $25, get the recommended make sure it is dialed in and working as expected, then you can think about dropping the size to 7. You COULD have an issue elsewhere, but with undersized nozzle there is no way to know.BoostfoSHO said:I have a Frankenstein kit builts from devils own nozzles hoses pump housing and fittings. And snow pump and controller. I think my system has always been working I was just under the wrong idea of nozzles I'm sure going to a higher no7 I'm sure it will solve the problemStealBlueSho said:Sounds like all that’s left is to up the spray....I am unfamiliar with DOs kit... can you adjust the pump to spray more without changing the nozzle?
This is why people should just order the Alky kit from Alky Control... it just works... every time....
