BoostfoSHO
derfdog15 said:Regarding hard plastic to not hard plastic, IMO I would source the quick disconnect connectors used on either end, completely remove the stock line and save it for later use if needed, and make a custom line setup using new quick disconnect connectors and your 3/8 fuel line.bpd1151 said:I tapped mine here, and added a T.
Biggest line for best consistent reference.![]()
If you aren't going to go the new connector route, then as others said, cut near the middle of the booster line, DO NOT cut close to the connector as it will be a pain.
This is what I was wanting to do I think it would be the cleanest and also allows me to keep the factory hose for whatever reason I may need to return to stock. Thank you I'm gonna go searching for the quick connector now.
