Macgyver said:
So what is your Idea on the HP Alt ?
Great question!
Welp...... the alternator I had up until this arrived, was the factory version, with 81k original on it.
My thoughts are that my massive audio system is running in excess of 10k watts of power. The factory one, probably wouldn't continue cutting it moving forward.
That power level is being pushed through four separate amps. Two 15" subs. Two 12" subs. Two 6x9's. Four 5x8's. Four tweeters.
Add in all the LED lighting, and a 16v meth pump that is twice the size of the Alky pump I was running, my concerns were that the factory alternator was insufficient.
This HP one pushes out nearly double the power of the factory. 370 amps, versus the factory 200 amps.
Running the bigger 850 Motorcraft, and a second, Interstate deep cell marine battery in the trunk, kind of dictates I move up to a HP alternator.
Make sense??
