"Complete" List of TSB's for your 2013+ SHO
-MANU URA Star.
.  Z
RECALL Subject : Fuel Pump Malfunction may Cause Engine Stall
Report Receipt Date: AUG 25, 2016
NHTSA Campaign Number: 16V621000
Component(s): FUEL SYSTEM, GASOLINE
All Products Associated with this Recall
2013-2015 FORD FLEX, FORD TAURUS, FORD TAURUS POLICE INTERCEPTOR, LINCOLN MKS, LINCOLN MKT
Details
Manufacturer: Ford Motor Company
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2013-2015 Ford Taurus, Ford Flex, Lincoln MKS and Lincoln MKT vehicles equipped with 3.5L GTDI Ecoboost engines and 2013-2015 Ford Taurus Police Interceptor vehicles. A component within the fuel pump electric module (PEM) may overheat causing a loss of electrical power to the fuel
pump.
CONSEQUENCE:
A loss of power to the fuel pump will cause the engine to stall or prevent the vehicle from starting, increasing the risk of a crash.
REMEDY:
Ford will notify owners, and dealers will inspect the fuel PEM part number and replace the fuel PEM, as necessary, free of charge. The recall is expected to begin September 12, 2016. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 16S31.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
A discussion on this recall
RECALL Subject : Fuel Tank Mounting Bolts may be Loose
Report Receipt Date: SEP 28, 2015
NHTSA Campaign Number: 15V605000
FORD EXPLORER 2016. FORD TAURUS 2015, LINCOLN MKS 2015
Details
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Taurus, Lincoln MKS, and 2016 Ford Explorer vehicles manufactured on July 24, 2015. During vehicle production, the fuel tank attachment bolts may not have been properly tightened. As a result, the fuel tank straps may fracture and the fuel tank could separate from the vehicle.
CONSEQUENCE:
If the fuel tank separates from the vehicle, a fuel leak may occur, increasing the risk of a fire.
REMEDY:
Ford will notify owners, and dealers will tighten the fuel tank attachment bolts, as necessary, free of charge. The recall began on October 19, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15S26.
NOTES:
RECALL Subject : Parking Brake may not Fully Engage/FMVSS 135
Report Receipt Date: JUL 24, 2015
NHTSA Campaign Number: 15V464000
Component(s): PARKING BRAKE
FORD EXPLORER 2015-2016, FORD FLEX 2015, FORD TAURUS 2015, LINCOLN MKS 2015, LINCOLN MKT 2015
Details
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Taurus, Ford Flex, and Lincoln MKS vehicles manufactured May 4, 2015, to May 23, 2015, Lincoln MKT vehicles manufactured May 4, 2015, to May 21, 2015, and 2015-2016 Ford Explorer vehicles manufactured May 4, 2015, to May 23, 2015. The affected vehicles have a parking brake that may not fully engage when applied. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 135, "Light Vehicle Brake Systems."
CONSEQUENCE:
If the parking brake does not fully engage and the transmission is left in a gear other than 'Park' while on a slope, the vehicle may roll away, increasing the risk of a crash.
REMEDY:
Ford will notify owners, and dealers will test the operation of the parking brake system, and if necessary, replace the parking brake control assembly, free of charge. The recall began on September 4, 2015. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 15C07.
NOTES:
TSB 15-0075 Adaptive Drive Malfunction Message in Instrument Cluster with Possible DTCs C110D & or C110C - Built on or before 5/4/2016
Vehicle Make Mode lModel Year(s)
LINCOLN MKS 2013-2015, LINCOLN MKT 2013-2015
SOME VEHICLES MAY EXPERIENCE AN ADAPTIVE DRIVE MALFUNCTION MESSAGE IN THE INSTRUMENT CLUSTER.
2016 Explorer/Flex/MKT/Taurus/MKS/Transit – 3.5L Gasoline Turbocharged Direct Injection (GTDI) – Illuminated MIL – DTCs P2096, P2097, P2098 And/Or P2099
October 30, 2016 Diagnostic Tips
Some 2016 Explorer, Flex, MKT, Taurus, MKS and Transit vehicles equipped with a 3.5L GTDI engine may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble code (DTC) P2096, P2097, P2098 and/or P2099 in the powertrain control module (PCM) memory.
This may be due to incorrect calibration values setting a system DTC instead of a circuit fault DTC. If the vehicle exhibits DTC P2096, P0297, P0298 and/or P2099, perform Powertrain Control/Emissions Diagnosis (PC/ED) pinpoint test DW Steps 9-12 first to validate the Heated Oxygen Sensor wiring.
If no concerns are found, continue with PC/ED pinpoint test DZ.
ASI-44333
2011-14 Explorers that are EXPORT, 2013-14 Police Sedan & Utility, Taurus SHO, Explorer Sport equipped with AWD and liquid-cooled PTU
SUMMARY:
FORD: DUE TO EXCESSIVE LUBE LOSS FROM PTU, OR INTERNAL PTU FAILURE, SOME TRUCKS, WILL EXPERIENCE CONTAMINATION OR SLUDGING OF PTU LUBE, RESULTING IN AN INCREASED INTERNAL LUBE TEMPERATURE. MODEL 2011-2014 EXPLORER, TAURUS SHO.
If PTU is replaced, replace the PTU vent hose base part number 7034 also.
NHTSA Campaign Number: 16V925
Manufacturer Ford Motor Company
Components ENGINE AND ENGINE COOLING
Potential Number of Units Affected 1,163
Oil Leak from Turbocharger
An oil leak, in the presence of an ignition source, increases the risk of a fire.
Summary
Ford Motor Company (Ford) is recalling certain model year 2016 Ford Taurus, 2016-2017 Ford Flex, Lincoln MKT, 2017 Ford Explorer and Ford Explorer Police Interceptor Utility vehicles equipped with 3.5L GTDI engines.
Improperly brazed turbocharger oil supply tubes may leak oil on engine components.
Remedy
Ford will notify owners, and dealers will inspect, and if necessary, replace the turbocharger oil supply tubes, free of charge.
The recall is expected to begin on January 23, 2017.
Ford’s number for this recall is 16S46.
Notes
Check if you Vehicle has a Recall
TO: All U.S. Ford and Lincoln Dealers
SUBJECT: NEW VEHICLE DEMONSTRATION / DELIVERY HOLD – Safety Recall 16S46
Certain 2016 Model Year Taurus, 2017 Model Year Explorer and Police Interceptor
Utility, and 2016-2017 Model Year Flex and MKT vehicles equipped with a 3.5L
EcoBoost Engine
Turbocharger Oil Supply Tube Inspection
AFFECTED VEHICLES
Vehicle Model Year Assembly Plant Build Dates
Taurus 2016         Chicago         October 18, 2016 through November 2, 2016
Explorer 2017                                 October 15, 2016 through November 12, 2016
Police Interceptor Utility                 November 2, 2016 through November 2, 2016
Flex         2016-2017 Oakville         October 18, 2016 through November 10, 2016
MKT                                                 October 18, 2016 through November 10, 2016
Affected vehicles are identified in OASIS and FSA VIN Lists.
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, improperly brazed turbocharger oil supply tubes may leak engine oil on the turbocharger and surrounding components.  An oil leak in the presence of an ignition source may increase the risk of fire.
SERVICE ACTION
Before demonstrating or delivering any new in-stock vehicles involved in this recall, dealers are to inspect the turbocharger oil supply tubes for leaks and replace if a leak is present.  This service must be performed on all affected vehicles at no charge to the vehicle owner.
OWNER NOTIFICATION MAILING SCHEDULE
Owner letters are expected to be mailed the week of January 23, 2017.  Dealers should repair any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter.
PLEASE NOTE:
Federal law requires dealers to complete this recall service before a new vehicle is delivered to the buyer or lessee.  Violation of this requirement by a dealer could result in a civil penalty of up to $21,000 per vehicle.  Correct all vehicles in your new vehicle inventory before delivery.
Attachment I: Administrative Information
Attachment II: Labor Allowances and Parts Ordering Information
Attachment III: Technical Information
Owner Notification Letter
QUESTIONS & ASSISTANCE
For questions and assistance, contact the Special Service Support Center (SSSC) via the SSSC Web
Contact Site.  The SSSC Web Contact Site can be accessed through the Professional Technician Society (PTS) website using the SSSC link listed at the bottom of the OASIS VIN report screen or listed under the SSSC tab.
Sincerely,
Michael A. Berardi
ATTACHMENT I
Certain 2016 Model Year Taurus, 2017 Model Year Explorer and Police Interceptor Utility, and 2016-2017 Model Year Flex and MKT vehicles equipped with a 3.5L EcoBoost Engine
OASIS ACTIVATION
OASIS will be activated on December 20, 2016.
FSA VIN LISTS ACTIVATION
FSA VIN Lists will be available through https://web.fsavinlists.dealerconnection.com on December 20, 2016.  Owner names and addresses will be available by February 3, 2017.
NOTE:  Your FSA VIN Lists may contain owner names and addresses obtained from motor vehicle registration records.  The use of such motor vehicle registration data for any purpose other than in connection with this recall is a violation of law in several states, provinces, and countries.
Accordingly, you must limit the use of this listing to the follow-up necessary to complete this recall.
SOLD VEHICLES
• Owners of affected vehicles will be directed to dealers for repairs.
• Immediately contact any of your affected customers whose vehicles are not on your VIN list but are identified in OASIS. Give the customer a copy of the Owner Notification Letter (when available) and schedule a service date.
• Correct other affected vehicles identified in OASIS which are brought to your dealership.
• Dealers are to prioritize repairs of customer vehicles over repairs of new and used vehicle inventory.
STOCK VEHICLES
• Correct all affected units in your new vehicle inventory before delivery.
• Use OASIS to identify any affected vehicles in your used vehicle inventory.
DEALER-OPERATED RENTAL VEHICLES
A new law prohibits a Rental Company from selling, renting or leasing vehicles subject to a safety or compliance recall. This could impact dealer-operated rental fleets of 35 vehicles or more, including FRAC, LRAC, and DDR vehicles.  Please see EFC04833 for details and consult your legal counsel for legal advice.
TITLE BRANDED / SALVAGED VEHICLES
Affected title branded and salvaged vehicles are eligible for this recall.
ADDITIONAL REPAIR (LABOR TIME AND/OR PARTS)
Additional repairs identified as necessary to complete the FSA should be managed as follows:
• For vehicles within new vehicle bumper-to-bumper warranty coverage, follow existing warranty and policy guidelines for related damage claims. No SSSC approval is required for these vehicles:
o Ford vehicles – 3 years or 36,000 miles o Lincoln vehicles – 4 years or 50,000 miles
• For vehicles outside new vehicle bumper-to-bumper warranty coverage, submit an Approval Request to the SSSC Web Contact Site prior to completing the repair.
OWNER REFUNDS
Refunds are not approved for this program.
RENTAL VEHICLES
The use of rental vehicles is not approved for this program.
LINCOLN PICKUP AND DELIVERY
Owners of 2017 model year and newer Lincoln vehicles have the option of requesting pickup and delivery service with a Lincoln loaner, from their dealership.  For details, reference EFC04786 National Launch of Lincoln Pickup and Delivery New Owner Privileges.
LINCOLN CLIENT SPECIAL HANDLING
To ensure the best possible experience for Lincoln owners, Lincoln Dealers are encouraged to utilize the Lincoln Loyalty Program to provide clients with surprise and delight offerings, such as:
• Fuel fill
• Gift Card for the client’s favorite restaurant
The Lincoln Loyalty Program is exclusive to Lincoln Dealers. Owners will not be notified of this service in owner mailings. Reference EFC04453, Lincoln Loyalty Program Announcement for additional details
CLAIMS PREPARATION AND SUBMISSION
• Enter claims using Direct Warranty Entry (DWE) or One Warranty Solution (OWS).
o DWE: refer to ACESII manual for claims preparation and submission information.
o OWS: when entering claims in DMS software, select claim type 31: Field Service Action. The FSA number (16S46) is the sub code.
• Additional labor and/or parts must be claimed as related damage on a separate repair line from the FSA.
• For Lincoln Client Special Handling, reference EFC04453, Lincoln Loyalty Program Announcement for Requirements and Claiming Instructions. Claims for Lincoln Loyalty should be submitted as a separate line on the same Repair Order.
• Provision for Locally Obtained Supplies: An allowance is provided for locally obtaining DyeLite Gasoline Engine Oil Dye.
o Program Code: 16S46            – Misc. Expense: OTHER
o Expense: Claim actual cost up to $10
ATTACHMENT II
LABOR ALLOWANCES
Description Labor Operation Labor Time
Inspect Turbocharger Oil Supply Tubes for Leaks – PASS/NO LEAKS (all vehicles) 16S46A 0.6
Replace RH Turbocharger Oil Supply Tube (includes inspect)
16S46B 1.9 Explorer and Police Interceptor Utility
        2.0 Taurus
        2.3 Flex and MKT
Replace LH Turbocharger Oil Supply Tube (includes inspect)
16S46C 1.2 Explorer and Police Interceptor Utility Taurus Flex and MKT
Replace BOTH Turbocharger Oil Supply Tubes (includes inspect)
16S46D 2.3 Explorer and Police Interceptor Utility
        2.4 Taurus
        2.8 Flex and MKT
PARTS REQUIREMENTS / ORDERING INFORMATION
Part Number Description Order Quantity Claim Quantity
-9G440- refer to catalog RH Turbocharger Oil Supply Tube
1 (as required) 1 (as required)
-9T516- refer to catalog LH Turbocharger Oil Supply Tube
XO-5W30-QSP
5W-30 Motorcraft Premium Synthetic Blend Motor Oil (12 quarts per package, up to 1 quart may be required) 1 1
Obtain Locally Dye-Lite Gasoline Engine Oil Dye
1 Fluid Oz. Bottle MISC OTHER
The DOR/COR number for this recall is 51068.
Order your parts through normal order processing channels.  To guarantee the shortest delivery time, an emergency order for parts must be placed.
NOTE:  Less than 5% of the affected vehicle population is expected to require turbocharger oil supply tube replacement.
DEALER PRICE
For latest prices, refer to DOES II.
PARTS RETENTION AND RETURN
Follow the provisions of the Warranty and Policy Manual, Section 1 – WARRANTY PARTS RETENTION AND RETURN POLICIES.
EXCESS STOCK RETURN
Excess stock returned for credit must have been purchased from Ford Customer Service Division in accordance with Policy Procedure Bulletin 4000.
ATTACHMENT III
vehicles equipped with a 3.5L EcoBoost Engine — Turbocharger Oil
OVERVIEW
In some of the affected vehicles, improperly brazed turbocharger oil supply tubes may leak engine oil on the turbocharger and surrounding components. An oil leak in the presence of an ignition source may increase the risk of fire. Dealers are to inspect the turbocharger oil supply tubes for leaks and replace if a leak is present.
SERVICE PROCEDURE
1. With the vehicle in NEUTRAL, position it on a hoist. Please follow the procedures in Workshop Manual (WSM) Section 100-02.
NOTE: Use the 12 Volt Master UV Diagnostic Inspection Kit 164-R0756 or equivalent (Leak Detector) to carry out the following procedure for oil leak diagnosis.
2. Add 29.6 ml (1 oz) of Dye-Lite Gasoline Engine Oil Leak Detection Dye to a minimum of 0.47L (1/2 qt) and a maximum of 0.95L (1 qt) engine oil and fill through the engine oil fill. Thoroughly premix the gasoline engine oil leak detection dye or it will not have enough time to reach the crankcase, oil galleries and seal surfaces during this particular 15 minute test. The additive must be mixed well with oil and added through the oil fill. Check the level on the oil level indicator to determine what amount of oil to premix. If it is in the middle of the crosshatch area or below the full mark, use 0.95L (1 qt). If it is at the full mark, use 0.47L (1/2 qt).
3. Run the engine for 15 minutes. Stop the engine and inspect the RH and LH turbocharger oil supply tubes for leaks using the 12 Volt Master UV Diagnostic Inspection Kit 164-R0756 or equivalent (Leak Detector). A clear bright yellow or orange area will identify the leak. See Figure 1.
NOTE: The LH turbocharger oil supply tube can be inspected from above, and the RH turbocharger oil supply tube must be inspected from below with the vehicle positioned on a hoist.
• If a leak is found at either turbocharger oil supply tube, replace the tube. Please follow the procedures in WSM Section 303-04.
• If a leak is not found, verify the oil level is within the upper and lower oil indicator marks.
Remove oil if it registers above the full mark. No additional service is required.
FIGURE 1
2017 Explorer/2016 Taurus – Missing Fuel Tank Filler Pipe Information Bezel – Built On Or After 9-Jun-2016
2017 Explorer and 2016 Taurus vehicles built on or after 9-Jun-2016 no longer have the fuel filler pipe information bezel attached to the fuel filler pipe.
The bezel was removed to comply with fuel pump vapor recovery equipment requirements and should not be considered missing.
The addition of the information bezel to units built on or after 9-Jun-2016 should not be done.
SB-10053412-4688
Manufacturer Communication Number: ASI-32238
Summary
FORD/LINCOLN: SOME VEHICLES MAY EXPERIENCE, A SLIPPAGE DURING SHIFTING OR POSSIBLE CLUTCH DAMAGE MIGHT HAVE HYDRAULIC FLUID LEAK IN VALVE BODY. MODELS 2013 EDGE, MKX, FLEX, TAURUS, MKT, MKS, MKZ.
everyone said they never seen it on a sho but actuator stuck closed and a trip to the dealer
interesting note
the original one you could see the gold galvanized blade nut on the side. i tried to use a crescent wrench to free it when i was stuck along the road
the replacement is a sealed unit-
The TB motor has been known to die on occasion.  That plate is like a snapping turtle, care must be exercised if the TB is electrically connected.
AJP turbo said:
That code also comes up as faulty wiring or a shorted throttle body wiring harness and even a bad pcm.
I remember you having problems with flashing the car and the ecu locking up.
Seems wierd that the throttle body blade seized up after all this time...you can usually push the throttle blade open with your finger...its just a plate on a shaft in a hole
What R U talking about ? that throttle blade will sever your finger right off if not disconnected properly and would advise caution.
It could also be a faulty electrical connector. Z
Sometimes i wonder what planet you are from...it wont sever your finger
Im just  saying if you took off the pipe and looked at the closed throttle blade you can easily push it with your finger if you were seeing if it was stuck
Zsho, are you the type of person that thinks it's appropriate that the car mfg's are required to tell people that the commercials are filmed on a closed course and should not be attempted?
You are not suppose to intervene with natural selection...if someone is dumb enough to do something that harms them then it was suppose to happen...you may be keeping people alive that shouldnt be
what's wrong with advising caution!!!! It will sever your finger off if precautionary measures are not taken that's all.
I think you need to move on my friend. Z
A lot of people never get into the knitty gritty of the mechanicals of their cars.  Many are simply not uptodate on the technology.  Doesn't make them dumb or foolhardy.
